Samsung 50uhd8550 standby led pressing power button does not turn TV on
  • waakye
    • Dec 2018
    • 340
    • Electronada
    #61
    Re: Samsung 50uhd8550 standby led pressing power button does not turn TV on
    Change DS811 and the power supply is back to life. Thanks all for helping. It was a learning experience for me.
      • 12141
      • U.S.
      #62
      You tested that diode in post #22, must have gotten a bad reading.
      • PNI E.
        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
        by PNI E.
        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
        03-17-2025, 04:23 AM
        09-07-2024, 05:50 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • Jackching
        Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
        by Jackching
        I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
        04-15-2024, 05:14 PM
