Grundig 32 LXW 82-8600 DL
  • bbccbb
    • Jan 2017
    • 53
    • Croatia
    The problem is with starting the TV.
    When it receives power it does not go into standby mode (from which it could be woke up to show the program).
    I have to switch power button on and off for cca 30-50 times and at some point it goes into standby mode in which I can use my remote to start watching the TV. If it loses power than I have to go throught the whole process again.
    Can somebody explain the standard process of switching the TV on?
    Just to try to understand where the problem could be.
  • Diah
    • Feb 2013
    • 6395
    Re: Grundig 32 LXW 82-8600 DL
    there are setting saved at SPI called "last state" ON or OFF if ON mean if the TV was in STB and plugged out from wall socket. it will come back to STB after plug in wall socket.
    if this "last state" OFF. always the set will turn on when it plugged to wall socket
    this setting could be find at normal setting menu... or some can be set only at service menu..
    if in service menu or at setting menu and there no effect at all after change ON /OFF... mean the SPI fault need new one to programmed and replaced or there Jammed need to have hard reset from service menu to initial the SPI to new condition.
    • bbccbb
      • Jan 2017
      • 53
      • Croatia
      Ok... thank you.
      I'll try to see if changing: options 0, standby does the trick.
      If not than Adjustments, reset...
      I'll report back.
      • R_J
        • Jun 2012
        • 9555
        You likely have a bad/weak capacitor in the power supply, likely a small electrolytic in the startup or vcc circuit. These small caps usually loo ok and not bulged but can be bad.
        Post some pictures of the boards and power supply.
        Search the forum for "LXW 82-8600" there are two threads on this.
        • bbccbb
          • Jan 2017
          • 53
          • Croatia
          Thank you!
          This post is exact replica of my problem!
          https://www.badcaps.net/forum/showthread.php?t=71789
          • R_J
            • Jun 2012
            • 9555
            Locate & replace C2056 and see if fixes your power supply, if it does, let us know.
            • bbccbb
              • Jan 2017
              • 53
              • Croatia
              I've got a different power board.
              I replied to a previous post with photos (as I should have and not open a new thread).
              Photos:
              https://www.badcaps.net/forum/attach...hmentid=224929
              https://www.badcaps.net/forum/attach...hmentid=224930
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • joelz
                pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
                by joelz
                Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
                11-18-2024, 06:02 AM
              • betmen
                Grundig Vision 7 42-7975 - menu pin
                by betmen
                I have one old Grundig tv which is working...but it have placed 4 digit pin for chanel scanning and some other settings.
                I don`t remeber pin any more so I can`t make any settings on tv.
                Does anybody know how to baypass or remove pin so I don`t have to write down 9999 or so 4 digit pin combinations to find out which one is it,
                I tried about 1500 so far...it is very boring and time consuming...
                07-05-2022, 10:58 AM
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
