Toshiba 43L3753DB Screen Issue
  • Russ17
    • Mar 2018
    • 125
    Re: Toshiba 43L3753DB Screen Issue
    Hi
    Update: When a source is connected to HDMI2, the screen just has lines.
    When I enter Service Menu (MENU 4725) the screen just has lines.
    Pressing Menu, gives a the menu options, but when you select an item, you get lines.
    The Mainboard from the 32" screen TV is not Full HD, so the ribbon connection is different as the panel is different (has in integrated T-Con), so trying that Mainboard is not an option.
    43" panel has a separate T-Con.
    The only option, without replacing the Main board, is to flash the firmware, assuming this can be achieved by just plugging in a pre-loaded Firmware file into the USB socket at switch on - is this a possibility?
    I would also need the firmware, which I don't have at the moment.
    Regards
    Russell
    • Russ17
      • Mar 2018
      • 125
      I also have a MB from a JVC 4K TV, could this be an option as it has the same connector type.
      • Russ17
        • Mar 2018
        • 125
        Re: Toshiba 43L3753DB Screen Issues - FIXED!
        OK, so I got in touch with Toshiba UK, who, after a few weeks, sent me an email link for the Firmware to download.
        I installed the firmware, but the result was the same.
        I started looking at the T-Con board, inspired by a You Tube video, where the guy had isolated one of the clock signals that synchronises the timing for the pixels on the LCD.
        When I inspected the T-Con closely, there was some unusual damage to the PCB (see Old T-Con picture).
        I looked on an auction site, and found a visually identical T-Con (going by the label), which the seller had quoted as being from a 32" TV, with part number 43 6817L - 3806DJEBN9AZ069, and the part number label on mine was 43 6871L - 3806BGKBDDV7747 (from a 43" TV).
        I decided to take a chance for £0.99p delivered.
        Long story short, it works perfectly!!!!
        I would surmise that the part number that matters is actually 43 6871L , with the remaining letters and numbers being a serial number of the individual PCB. The part number that is silk printed in white, on both PCB's is 6870C-0532A and the design date is identical 2014/03/19.
        Hope this helps someone.
        How do I upload the Firmware to this website?
        Thanks to all those who have helped me out.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4287
          • Italy - Milan
          Lucky, i would have bet panel.. the old tcon is fixable i think, search for a stand alone little power mosfet, that is maybe faulty.. maybe q1 or q2..
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Hi Russ,
            If you can give the set model number, mainboard and LCD panel number and add it to the EEPROM Dump Thread. You should be able to zip the file and add it to your message using "Go Advanced" then add the file using Manage Attachments.
            Good luck
            • Russ17
              • Mar 2018
              • 125
              Originally posted by dick_barton
              Hi Russ,
              Good luck
              Dear Dick,
              Mainboard is 17MB110P.
              Model is Toshiba 43L3753DB
              I don't know the LCD Panel number, and the TV is now reassembled and is on the wall, so it not accessible.
              I will add the zip file of the Firmware to the EEPROM Dump thread.
              Regards
              Russell
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                Thanks. I'm sure it will be ueful for someone at a later date.
                • Russ17
                  • Mar 2018
                  • 125
                  Dear Dick,
                  I have zipped the 4 files, but I am struggling to upload it. I opened the attachment manager, attached the zipped file, but the upload sits at 0%
                  Any ideas?
                  Russ
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #29
                    What is the size of the zip files?
                    • Russ17
                      • Mar 2018
                      • 125
                      143Mb
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #31
                        Unfortunately the maximum zip file size you can attach is 28MB.
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          #32
                          Thanks for the file.
                          Here is the link to your firmware spilt into 4 parts which can be recombined using WinRaR
                          https://www.badcaps.net/forum/showpo...&postcount=899
                          • jjanssen7
                            • Nov 2012
                            • 252
                            Good solution!
                            By the way, I've seen that kind of damage before. Somebody used too long of a screw/bolt securing the stand to the TV or the TV to the wall!
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4287
                              • Italy - Milan
                              #34
                              Sorry, i've understood now, the fault was the screw hole on pcb right? So there was no metal shield?
                              • jjanssen7
                                • Nov 2012
                                • 252
                                I don't know about his case, but I've seen them go right through the shield. It's one of the first things I look for because it's so easy to spot.
                                • wizard13
                                  Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                  by wizard13
                                  I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                  I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                  • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                  • Part Number (P/N): PYU13E-00C00PFR
                                  • Serial Number (S/N): 22028896H
                                  • System Configuration (SC): A1PYU13E1127
                                  • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                  • Power Input: DC 19V –
                                  02-28-2025, 02:43 AM
                                • Yehuda170
                                  ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                  by Yehuda170
                                  original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                  replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                  now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                  with original broken screen i can see in device manager touch screen in human interfaces
                                  but with the new screen it's not showing in device manager
                                  is it lenovo blocking it? is it driver missing?
                                  I²C is a headache
                                  07-14-2023, 01:29 AM
                                • cloudy
                                  HELP - Contrast/brightness issue with subtitles on screen
                                  by cloudy
                                  Hi everybody
                                  Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                                  Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                                  Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                                  It occours both on ubuntu and windows...
                                  01-01-2023, 05:12 PM
                                • Verlengsnoer
                                  Toshiba C660 Black screen/reboot issue in combination with Nvidia
                                  by Verlengsnoer
                                  i have a Toshiba c660 laptop, with i5 and nvidia
                                  When installing the driver for the nvidia gpu, the screen goes black in a few minutes, and the laptop restarts itself
                                  when i uninstall the nvidia driver, the laptop works fine but choppy video because of the missing video driver.
                                  i tryed a random bios backup, just to see if it is a bios based issue, tryed to reflowed the nvidia chip, but nothing seems to fix te nvidia/reboot issue
                                  hope some of u have some tips (im not technical in measuring voltages or other hardware based...
                                  04-05-2022, 01:20 PM
                                  09-06-2024, 05:27 AM
