Re: Sharp LC-50LB371C LED TV VERTICAL LINES
I think it ruined the output traces on the tabs, so don't expect much, check the green side of them..
It certainly would cause problems. Hopefully a good clean and the set will be back in good order.Leave a comment:
sorry i can't explain it betterLeave a comment:
Buf why other ideas? I have given you an idea, you have done what?...Leave a comment:
yes.. so basically,, if you detach tcon from the large screen boards , then you flip them you see the green part of the tab where there is a chip, ok you must put a shim under it provisional, then you put eveeverything normal and you warm under the chip especially in the zone that makes appear again the missing lines, so this test at tv switched on, i have near reapaired one this way.Leave a comment:
defenately not, i'm at hospital now..Leave a comment:
Can you please send a picture of where I do thisLeave a comment:
if you detach tcon outputs its normal that lines go.away since there is no more signal, locate the tabs where appears bad columns, then put a shim under them, then warm the back of the chip so on the amber side with a sokdering ironLeave a comment:
Try wiggle or shake the video input cables, see if that helps.Leave a comment:
How do I test the T-Con board to confirm it works or not?Leave a comment:
Only repeating lines/patterns may be tcon issues. Single random vertical lines or bands are bad panels.Leave a comment:
I think it's a bad tab bond, try tapping on the bezel, NOT the screen where the line is, see if the line goes away or changes any.Leave a comment:
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
tried blocking LC lines too, but same results
is it lcd panel issue or tcon board issue?... -
by gpo23Hello,
i order a t-con because i had bad colors on my SONY KDL-40V3000 :
With the new t-con the color are good but there are vertical lines on all the screen :
I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
Is there a way to fix the vertical lines on the new t-con ?
Thank you for your help
gpo23... -
by FirentiosiThanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
The issues are as follows: the...2 Photos -
by viking509I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
- Loading...
