pn64e550d1fxzc power issue
  • pansatdishman
    • Jun 2013
    • 110
    hello i have a pn64e550d1fxzc powers off and on power supply issue ? thanks
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: pn64e550d1fxzc power issue
    It could be almost anything unfortunaely without some voltage readings being taken.
    Are Vs and Va trying to reach the voltage given on the label on the back of the panel?
    Have you checked to see if there is a short circuit from Va to chassis, Vs to chassis?
    Do you have photo's of your boards.
    • Nick's Tvs
      • Jan 2014
      • 621
      To add onto Dick_barton's comment, it would also be nice to know more detail about the powers off issue you described. Does it turn on and work for an hour before it powers off or does it power off before picture can even appear on screen?
      • pansatdishman
        • Jun 2013
        • 110
        tvs powered on now but sometimes it shuts of when warm? when it turns off again ill take it apart and look. any known cap issues or cold solder joints i should look for thanks
        • pansatdishman
          • Jun 2013
          • 110
          tvs still working
          • pansatdishman
            • Jun 2013
            • 110
            update turned tv off for 45 mins unplugged plugged it back in. within 5 mins it powered off then powered back on then i couldnt power it back on it did sit in my car last night and it was very cold.
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              Touch up all the solder joints on the power supply board.
              • pansatdishman
                • Jun 2013
                • 110
                can putting it in the oven fix the solder joints?
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  I would use a soldering iron, not an oven. You will melt all the plastic and blow up the capacitors!
                  • pansatdishman
                    • Jun 2013
                    • 110
                    Okay thanks all the solder joints? I haven't tooken it apart yet it won't turn on now.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      At least do everything mounted to a heatsink and under a transformer. Use 60/40 leaded solder.
                      • pansatdishman
                        • Jun 2013
                        • 110
                        Thanks ill have to pick that up take it lead free won't work? And does diameter matter?
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          I use .6 to 1 mm diameter.
                          • pansatdishman
                            • Jun 2013
                            • 110
                            thanks never had chance to grab the solder yet. so my tv wont power on this can still be the cause
                            • tvtimmy
                              • Mar 2015
                              • 1160
                              • usa
                              These 3 blue capacitors marked as 106 need to be replaced also. They are 10uf 50volt.
                              See pictures below. They will prevent the tv from turning on. They are on the y-main board.
                              • pansatdishman
                                • Jun 2013
                                • 110
                                Thanks what type of capacitors are they I'm use to changing electrolytic capacitors, and what rating do you recommend? Thanks
                                • tvtimmy
                                  • Mar 2015
                                  • 1160
                                  • usa
                                  I have used electrolytic caps in this repair. You have to figure out what side is the negative and the positive. I can't remember, but it was easy to figure out.
                                  • pansatdishman
                                    • Jun 2013
                                    • 110
                                    thanks can you post a pic to make sure i get the right kind thsnks
                                    • tvtimmy
                                      • Mar 2015
                                      • 1160
                                      • usa
                                      First picture is the recommended replacement caps. Second one is correct polarity of electrolytic capacitors. The stripe side with shorter leg is negative.
                                      • pansatdishman
                                        • Jun 2013
                                        • 110
                                        thanks they just came today trying to desolder the old ones but having a hard time getting a hole for the leads using a 25w weller solder gun amd ive soldered and desoldered caps before thanks
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
