hello i have a pn64e550d1fxzc powers off and on power supply issue ? thanks
pn64e550d1fxzc power issue
Tags: None
Re: pn64e550d1fxzc power issue
It could be almost anything unfortunaely without some voltage readings being taken.
Are Vs and Va trying to reach the voltage given on the label on the back of the panel?
Have you checked to see if there is a short circuit from Va to chassis, Vs to chassis?
Do you have photo's of your boards.Last edited by dick_barton; 11-14-2020, 09:10 AM.Willing to help but I'm no expert. -
To add onto Dick_barton's comment, it would also be nice to know more detail about the powers off issue you described. Does it turn on and work for an hour before it powers off or does it power off before picture can even appear on screen?Comment
tvs powered on now but sometimes it shuts of when warm? when it turns off again ill take it apart and look. any known cap issues or cold solder joints i should look for thanksComment
update turned tv off for 45 mins unplugged plugged it back in. within 5 mins it powered off then powered back on then i couldnt power it back on it did sit in my car last night and it was very cold.Comment
Okay thanks all the solder joints? I haven't tooken it apart yet it won't turn on now.Comment
Thanks ill have to pick that up take it lead free won't work? And does diameter matter?Comment
thanks never had chance to grab the solder yet. so my tv wont power on this can still be the causeComment
Thanks what type of capacitors are they I'm use to changing electrolytic capacitors, and what rating do you recommend? ThanksComment
thanks can you post a pic to make sure i get the right kind thsnksComment
thanks they just came today trying to desolder the old ones but having a hard time getting a hole for the leads using a 25w weller solder gun amd ive soldered and desoldered caps before thanksComment
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by justice171I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:- Verified that all critical voltages are present:
- 3.3V and 5V are always present if DC is plugged.
- 1.8V on the BIOS chip is present.
- Checked the power button functionality:
- When pressed, the voltage drops to 0V, indicating the button is functional.
- Inspected the flex cable connecting the USB, audio, and power button to JUB1:
- Confirmed connectivity is intact, ruling out issues
11-26-2024, 12:39 AM - Verified that all critical voltages are present:
Assuming...7 Photos -
by claws77hi guys, my motherboard will not start no matter what
when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
but rest nothing happens no sign of life.
this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
but now nothing happens no matter how much i wait/ charge/ press and hold power button.
i have no knowledge of motherboards ....10-20-2024, 02:48 PM -
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM - Loading...
