Westinghouse EW50T5KW no backlight
  • speter
    Been around the
    • 77
    Re: Westinghouse EW50T5KW no backlight
    Q103 was disconnected for that.
    Q103 temporarily shorts B+ to ground and kind of twangs the L101 transformer, to double the voltage?
    I had no voltage on PFC_Vcc without BKon jumpered, varying voltage between 1 and 8v when BKon was jumpered
    I had / have 13v for VCC
    Goshen NY, USA
    • speter
      Been around the
      • 77
      Giving up. Ordering another board.
      I wonder if I input 220v or more to it, if it would make any difference, as the boost circuit would not be needed The Ps is rated 100-240v
      I could easily supply it with DC, but I don't a step up transformer for AC
      Tried 350vDC (should be safe, as 240vac is a higher peak voltage), no change, likely something with the boost transformer
      It seems as though the board will do DC just fine, as both 12v and 5V were present
      Goshen NY, USA
      • Nicktronic
        Westinghouse W55UW4620 No Video
        by Nicktronic
        Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
        So, backlights, no video, go! 🙂...
        06-03-2024, 03:21 PM
      • EBW
        Help Request - Westinghouse 32" Smart TV (Model: WD32HBR105)
        by EBW
        Westinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...
        10-27-2022, 06:32 PM
      • Seville
        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
        by Seville
        Hello all!
        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
        I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
        10-10-2022, 07:31 AM
      • JayPoorJay
        Westinghouse Roku WR58UX4019.To be or not TV,,, That is the Question
        by JayPoorJay
        Hi All... Me again. Begging for help. The guy who now believes it's possible to fix a TV (one of the millions) one can find on the streets of NYC. I hate hate hate waste...
        Thanks to y'all's help I fixed and am happily watching a 70inch Sharp Aquos. Perfect. Learned a lot, replaced LEDs. Pulled screen/panel. Proud.
        This is a newer set. It's a Westinghouse Roku WR58UX4019. It was RIGHT outside my place literally, and I couldn't resist. 58in. 500$ new, but I'm not a rich man. So, I want to try.
        There is sound. It turns off and on. Screen is black. I can...
        03-17-2022, 05:27 PM
      • flashcoder
        Westinghouse DWM40F1G1 backlight blinks and turns off
        by flashcoder
        I got this TV (Westinghouse DWM40F1G1) that did not came on one day, blinked for a split second and turned off. I looked at it closer with flashlight and figured that the TV actually works, its just the backlight that does not.
        There is one PCB board - all of the components are on it: TP.MS3393.P85
        I took my oscilloscope and looked what is coming to the MOSFET that is switching current to LEDs - I could see that the PWM signal comes in but it cuts off almost instantly. I thought its the driver chip OB3350CP and so I replaced it.
        After that the...
        11-16-2021, 02:12 AM
