Sharp LC-70LE847U 3-1 blinks - troubleshooting
  • haggisnbabgpipes
    • Nov 2020
    Hi everyone! New to the board and I've gone through a bunch of other threads discussing the same thing however I can't seem to nail down the issue. Any help would be fantastic.
    -Screen doesn't turn on at all. During power up, the green light on the main board flashes once
    -I get the 3 slow blinks then 1 fast which should mean a comm issue
    -Tried the various resets (input/vol down plug in, hold power on then plug in etc). No image or K tries to come on.
    -No backlight comes on
    -Tried removing various T-Con ribbons, left only, right only, all of them, to see if I could get backlighting but nothing comes on.
    -checked voltage at the PSB regulator - during power up i get 13V at pin 1, 12v at pin 2, 3v at pin 4. This to me means the main board is telling the PSB to supply power correct?
    -checked voltage at pins 14 and 16 during power up and they are both producing 3v
    Any thoughts that could help me land on a certain board for replacement? I'm thinking it's not that panel as I can't hear any sound? I'm not sure if I even would though with this error code.
    Here's a link with pictures of the back of the TV including panels
    https://photos.app.goo.gl/cJzT3f2j4PLfAfmw9
    Thank you!
    Mike
  • advant
    by advant
    02-03-2020, 12:25 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • JTon
    Sharp LC-42D69U - New Main Board - No Display Troubleshooting
    by JTon
    I'm asking for some ideas/guidance on where to go next with my troubleshooting efforts.
    A history of events so far:
    • TV was dead. No signs of life, no standby light. Nothing.
    • Replaced power board. No results. Same issue (oops)
    • Replaced main board. Local supplier only had a variant board in stock. As far as I can tell, this board is used for the TV's smaller cousin (LC-32D59U). It has the same printed part number, but different sticker numbers.
    • I had to buy a new pin header, and solder to the new board to connect the display signal cable.
    • TV now enters
    04-23-2021, 09:07 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • huj3r
    Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
    by huj3r
    Hi there!
    I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
    Photo of the situation after the black shadow dissipates:
    After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
    I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
    > This indicates HFR Communication error. [ HFR Communication...
    08-15-2023, 10:55 AM
