SONY KDL-55HX850 : No backlight, no error code, rest OK
  • Diah
    • Feb 2013
    • 6364
    Re: SONY KDL-55HX850 : No backlight, no error code, rest OK
    Originally posted by Jojo337
    Hi !
    F2001 : Continuity OK (beeping), 0.001v, 0 ohm
    1) LED_ON is ~-0v in standby and 3.28v TV on
    2) VLED_VCC are 0v in standby, go up to 0.140v EACH 4 VLED_VCC for 2 secs and go down to 0V 3 sec later progessively.
    Thanks again !
    LED back light in this Sony are parts of VLED_VCC circuits, if there OPEN LED Ziner Diode all Circuits turned off and the set remain ON with no error. time to repair LED BL. as i wrote before search for other hands to help you with this risky job.
      Hi !
      Thanks again !
      Now remove the connector from CN6601 and repeat the same test on VLED_VCC pin again.
      BTW, you did already test D6602, 03, 12, 13?
        No power to the TV:
        Check the resistance of R6707.
        Turn on the TV and check the DC V between the two legs of C6530, be real careful since you are working on the Hot deadly side of the circuit., then check the DC V between the negative leg of C6530 against each leg of R6707.
        • Jojo337
          • Oct 2020
          • 21
          • FRANCE
          I was hopping that the leds be all good but my hope is going down
          Anyway here are the results, if my tests are correct :
          Diodes (multimeter to diode mode) D6602, 03, 12, 13:
          1.140v 0.425
          1.140v 0.425
          1.140v 0.425
          1.145v 0.423
          If I disconnect CN6601 everything is at 0v except 0.7V pin 11 LD_ERR
          (startup or not) The TV works fine behind except of course BL
          R6707 2.2ohm
          Stby C6530 395v, 13.88v with postive on R6707 (the two legs)
          TVON same but 14v on the two legs.
            1.140v 0.425
            1.140v 0.425
            1.140v 0.425
            1.145v 0.423
            R6707 2.2ohm
            So there is no action even when the output of the power supply is not connected to the LED driver board, the power supply should put out around 50V, then if there is error the power supply will be shutdown due to error, right now the SMPS IC for the LED power supply is getting the VCC (13V) to run, but no action.
            There are many LED strings in this panel and they are driven by many LED drivers, so the one with good LED should at least flash on for seconds before the protection kicks in.
            BTW, you did leave the meter in place to monitor VLED pin of CN6601 when TV is turned on to catch the Voltage when TV is first turned on, correct?
            • Jojo337
              • Oct 2020
              • 21
              • FRANCE
              #26
              I retested CN6601 not plugged, meter in place, first turn on, in fact all pins of CN6601 except NC and LD_ERR are -0.01v in stby and goes "down" to -0.02v when turning on.
              No flash at all from leds even a micro flash (verified in dark room).
                Opening up the LCD panel is the last thing I would do since if you have never done one you can easily damage the screen, damage the tab bonding.
                I will look at the spec of the SMPS IC to do more verification.
                • Jojo337
                  • Oct 2020
                  • 21
                  • FRANCE
                  #28
                  I already do it for a samsung 40d5003 (in fact I'm waiting the new leds to come...) but here it's a 55, glass panel in front (strange design even if "beautiful").
                  SMPS IC : IC6701 ?
                    SMPS IC : IC6701 ?
                    Yes, that is the IC, need to look for spec sheet and see if there is error detection pin that will put it into shutdown mode.
                    • Jojo337
                      • Oct 2020
                      • 21
                      • FRANCE
                      #30
                      Impossible to find the sheet, maybe this is the same ?
                      https://www.datasheetq.com/CXD9969P-doc-Sony (lack the A)
                        I found the schematic of how the CXD9969 is used.
                        Please check the Voltage on pin 1, and pin 8 of the IC against the negative leg of C6530.
                        • Jojo337
                          • Oct 2020
                          • 21
                          • FRANCE
                          #32
                          CXD9969AP IC6701
                          STBY : Pin 1 0.1v - Pin 8 13.8v
                          ON : Pin 1 0.1v - Pin 8 14v
                          • Jojo337
                            • Oct 2020
                            • 21
                            • FRANCE
                            #33
                            So I got some time today to dissasembly it...
                            It was a nightmare, but I got the 4 led strips. One led was down.
                            But during disassembly of each, the first led self destruct itself (sticked to one of the reflector layer). When testing the first led never light up (I suppose broken during disassembly) but every other do... except one lost in one strip, it sure be defective befor I didn't touched it.
                            I'm ordering all 4, I hope I didn't destroyed any other thing (I reassembled it without screws and it seemed ok, even the picture seems ok but not sure if there is any lines... I will see.)
                            Thanks.
                              • 12167
                              • U.S.
                              #34
                              Ok, then it looks like it was a bad backlight/s, trying to figure out why it could not be determined by just seeing if there was expected voltage on powerboard at backlight connector with backlights unhooked??
                                Can we see the LED strips?
                                What did you use to power up the strips? So how many strips are bad? Two?
                                BTW, pin 1 Voltage which is the Boost Voltage sensing pin to make sure the PFC Boost Voltage is not too low, it should be > 2V on that pin 1, at 0.1V it thinks that the PFC Voltage is bad so it will stay in protection mode.
                                • Jojo337
                                  • Oct 2020
                                  • 21
                                  • FRANCE
                                  #36
                                  Here are the pictures of the led strips.
                                  All 4 are defective now (the first led was "sticked" to a plastic reflector, maybe by heat...
                                  I got a led tester. I put LED + to one of the + of the strips, and with the LED - I go to all - of the strips, each - illuminate 8 leds.
                                  Just one led was already defective it seems, looks cracked. By disassembly it I certainly broke the first leds of each 4 because they were sticked to the reflector, IDK why, there isn't tape.
                                  • Diah
                                    • Feb 2013
                                    • 6364
                                    i don't think its your fault... because heat and the reflector very close to leds surface. just dont forget to clean the edge of the reflector to have clean display..before 3year or more i had got this edge 7030 led. i removed them all with heat gun and placed pasta then stick new ones after all are in place and straight i applied the heat from downside of the strips so all got in place with good middle ground contact.. on aliexpress i got them 100 pieces for about 5$
                                    • Jojo337
                                      • Oct 2020
                                      • 21
                                      • FRANCE
                                      #38
                                      Hello all.
                                      The new LEDS are in place.
                                      Nothing seems to be "more broken" after I dissasemble it.
                                      However the backlight still doesn't works
                                      Any others ideas, maybe it's the PSU ? The driver LED seems cold when touching.
                                      With my phone flash I see that the BL is not at 0 in the settings
                                      Thanks and have a good day !
                                      • Jojo337
                                        • Oct 2020
                                        • 21
                                        • FRANCE
                                        #39
                                        Ok so I replaced the PSU and the TV works, however there is two lines in the screen, so maybe I broke IT or it was already there, I don't know !
                                        Anyways the PSU was faulty !
                                          So if you check the Voltage per my post #35, what do you get?
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
                                            Sony VAIO SV-T1122F4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SV-T1122F4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SV-T1122F4E boardview and SV-T1122F4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
