LE40A656A1F Dark image in the middle
  • sigmeyer
    • Feb 2020
    • 158
    • Serbia
    Hello i got this TV as a part of a lot of broken TV's , this one works fine but had horisontal lines across the screen. I cleaned the LVDS cable and also the screen cable and connecter , the lines are gone but i have this dark image with weird effect on the left side of the screen as you can see on my video. The connecter which goes to the screen i could not clean because its unreachable atm , i would have to take the whole screen apart. See in pictures. Do you think its possible its T-Con board? How do i preform some tests to rule out the logic board? Also when i bring up the menu , its also dark. https://www.youtube.com/watch?v=qF3EFKYvtHE
  • sigmeyer
    • Feb 2020
    • 158
    • Serbia
    Re: LE40A656A1F Dark image in the middle
    Also if i even touch the ribbon cables the horizontal lines come back. Could it be that the cables are faulty?
    • nomoresonys
      • 12328
      • U.S.
      Could be, they shouldn't freakout just by touching them.
      • sigmeyer
        • Feb 2020
        • 158
        • Serbia
        I think its actually one of the ribbons connecting to the panel.. and by me touching the ribbons on the tcon it actually moves the board connecting to the screen... i bet the panel is shot.
        • sigmeyer
          • Feb 2020
          • 158
          • Serbia
          I ruled it out as a panel problem , i saw some pictures of usual screen failure , and it looks really like what i have on mine. The shadow in the middle i mean. I cannot explain the ghosting on the left side tho, Could be just the symptom of a display going bad. I saw some people hook the 24volt supply on one of the side ribbons that fixed some of the issues like horizontal lines , but i dont think the shadow is fixable , so i just left it as is. Selling it for parts. Thanks for the response tho. Hopefully next one is fixable.
          • nomoresonys
            • 12328
            • U.S.
            Could strip it down a little to get to the tabs, if applying a little pressure on the tabs clears it up, it could probably be shimmed. The tv/monitor I'm looking at right now was shimmed a couple years ago, had the dark/shadow/ghosting going on too.
            • dicky96
              HP Elitebook Screen blank - backlights but no image
              by dicky96
              Hi guys
              I'm trying to fix this laptop screen
              Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
              OK so I have the original screen which works but has lines across the bottom quarter of the screen
              I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
              04-28-2021, 07:30 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • speedtime07
              i life zed air cx5 no image on screen
              by speedtime07
              hi everyone ,
              There is an image on the external computer screen ,
              flexi cable test ok - screen test ok -
              What alternative should I look for?
              thank you for your support​
              04-10-2025, 06:24 AM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
