Hello, can somebody looks at this, got TV with vertical lines, screen tot cracked, after tv is turned on, lines appearing on screen and fade out in ab 5-10 sec, after pressing menu or home, appearing again and fade out in some time, voltage on PS looks ok, there is no separate tcon, that looks to me like LCD failure, I checked all caps on lcd boards, no short, can somebody help me to check voltages like VGL VGH
Samsung un58mu6100 vertical lines, fade out in 10 sec
Re: Samsung un58mu6100 vertical lines, fade out in 10 sec
I think VGH should be a positive voltage and VGL a negative voltage.Willing to help but I'm no expert.Comment
Found one bad resistor on VGH line R403_P01M, on marking was 330 (underscored 0) suppose to be 33 Ohms, measured from 5KOhms to 50Kohms.
After replacement lines are gone but there is no picture and TV is powering off after 1-2sec, Q499, Q498, Q497 looks ok (tried to replace) same result
Some more progress... I found issue, on left LCD board, resistance between VGL AND VGH was 29 Ohms, same time on right one nothing I cut off VGH signal next to brown flax ribbon and was able to start LCD, got picture but half of screen is slowing down and colors are bad, is there any chance to fix it, or it's dead already?
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by x_orange90_xI posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went... -
by polaroGreetings,
I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by AnonmisHello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly... - Loading...
