Samsung un58mu6100 vertical lines, fade out in 10 sec
  • xfox
    • Feb 2018
    • 84
    Hello, can somebody looks at this, got TV with vertical lines, screen tot cracked, after tv is turned on, lines appearing on screen and fade out in ab 5-10 sec, after pressing menu or home, appearing again and fade out in some time, voltage on PS looks ok, there is no separate tcon, that looks to me like LCD failure, I checked all caps on lcd boards, no short, can somebody help me to check voltages like VGL VGH
  • CapLeaker
    Leaking Member
    • 8325
    Re: Samsung un58mu6100 vertical lines, fade out in 10 sec
    looks like someone cleaned the tv and water ran into the tab bonds.
    • petehall347
      • Jan 2015
      • 4439
      • United Kingdom
      who is swinging off that fan ?
      • xfox
        • Feb 2018
        • 84
        Just checked VGH and VGL:
        VGH: -7.8V
        VGL: -8.0V
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I think VGH should be a positive voltage and VGL a negative voltage.
          • xfox
            • Feb 2018
            • 84
            Found one bad resistor on VGH line R403_P01M, on marking was 330 (underscored 0) suppose to be 33 Ohms, measured from 5KOhms to 50Kohms.
            After replacement lines are gone but there is no picture and TV is powering off after 1-2sec, Q499, Q498, Q497 looks ok (tried to replace) same result
            • xfox
              • Feb 2018
              • 84
              Some more progress... I found issue, on left LCD board, resistance between VGL AND VGH was 29 Ohms, same time on right one nothing I cut off VGH signal next to brown flax ribbon and was able to start LCD, got picture but half of screen is slowing down and colors are bad, is there any chance to fix it, or it's dead already?
              • xfox
                • Feb 2018
                • 84
                Was temporary able to remove short, but late came back, LCD trashed, boards for sale...
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • x_orange90_x
                  Samsung UN46C8000XFXZA vertical bars/horizontal lines
                  by x_orange90_x
                  I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                  The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                  09-04-2023, 12:09 PM
                • polaro
                  Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                  by polaro
                  Greetings,
                  I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                  08-27-2022, 08:46 AM
                  09-07-2024, 05:50 AM
