Sony KDL-40WE663 Screen problem
  • willday
    • Oct 2020
    • 18
    • United Kingdom
    Re: Sony KDL-40WE663 Screen problem
    Am now searching for a mainboard with exact same numbers on the board, no luck in finding yet
    • Diah
      • Feb 2013
      • 6439
      Originally posted by willday
      Entered into Sony Service menu, board is showing correct tv model KDL-40WE663
      Many many settings to look at and possibly change, but I would not know which ones I may need to change or what to change a setting to
      i thought you will upload photos here.. any way
      from service menu do factory reset. to register yours panel T-CON at the new firmware.. let see if it solved
      • willday
        • Oct 2020
        • 18
        • United Kingdom
        Hi Sorry did not realise you wanted pics, I will again do a factory reset and take some pics for you.
        Is there an option to do a factory reset through this service menu ??
        The factory reset that I have done, I did through the normal tv settings menu
        • Diah
          • Feb 2013
          • 6439
          it may listed reset option at service menu under different name such as "factory default".. also you have option of self check. this will diagnose whole hard ware and if there are error for example at T-CON will be listed too. self check are very useful option at SONY.
          • willday
            • Oct 2020
            • 18
            • United Kingdom
            Hi Diah, firstly thanks for the help on this tv
            Have done a reset through this service menu same result on right hand side of picture
            Here are the pics of the service menu, one thing I had a quick look at was the panel selection, it lists about 12 different panels, maybe that may need changing if this board is for a different panel as to what is fitted in this tv
            • willday
              • Oct 2020
              • 18
              • United Kingdom
              #26
              Looking at my pictures of the lvds driver board screen fitted to this tv is a LSY 400HN02
              • Diah
                • Feb 2013
                • 6439
                take looks on yours TV chassis there should be barcode or label show the panel No.
                in case you couldn't find label. you can pattern the listed Option at Panel Selection. Choice one and test..
                • willday
                  • Oct 2020
                  • 18
                  • United Kingdom
                  #28
                  UPDATE
                  Ok a revisit on this tv, I have just sourced a mainboard after many many months of searching for this tv exact same numbers as faulty board
                  Fitted the board and tv picture is still showing same fault as previous boards ie hazy patch and pattern on right hand side of screen as in my previous posts
                  I have updated software and factory reset still same pattern and haze on screen
                  Any ideas please
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    #29
                    You might try Budm suggestion. Firmware can't fix everything. Seems to be a thermal problem.
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • CyberPhoenix
                      Issue with picture quality of Sony bravia TV
                      by CyberPhoenix
                      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                      01-22-2024, 02:08 AM
                    • arbitarytwist
                      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                      by arbitarytwist
                      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                      03-01-2025, 01:16 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
