Help! Can't fix Samsung 60" TV UN60J6200AFXZA
  • rprilutsky
    • Oct 2020
    • 7
    Here is a picture on my Samsung 60" UN60J6200AFXZA
    https://photos.app.goo.gl/1iXQ6ZgJyDCBnXnM9
    Tried all I could: replaced the t-con board and mainboard. Swapped all cables. I see no defect on the panel cables either and touching them does not change the picture. I have no idea what to do next. Any help is greatly appreciated! Thanks!
    • 12206
    • U.S.
    Re: Help! Can't fix Samsung 60" TV UN60J6200AFXZA
    Doesn't look like anyone wants to try on the sammys, I'll try to help you, do you have a multimeter for testing? Can you use the attachment to post some good clear str8 on pictures of each board and one of the whole back to see how they are arranged?
      Show us good clear pictures of the backside of the TV showing all the boards using GO ADVANCED to attach the pictures..
      What Voltage testing have you done so far?
      • rprilutsky
        • Oct 2020
        • 7
        Thanks! I have scope and voltmetter (multimeter). I did not do any voltage testing yet. Here are the pictures:
        • rprilutsky
          • Oct 2020
          • 7
          and one more
            • 12206
            • U.S.
            Check the voltages at connector CNM803, see the little map/legend nearby? check voltage with tv in standy, then power on tv and check them again, report both conditions here, so put pin # pin name like ps-on and the voltage. Positive probe on pin, neg. on metal chassis ground, you may have to use something pretty small to check some of them, I use a very small needle to get contact with the pins that are not easily accessible, looks like you can reach the top pins easily from the rear of the connector.
            • rprilutsky
              • Oct 2020
              • 7
              Thanks! Here are the results
              In standby mode:
              1 - 11.1v
              2 - 11.1v
              3 - 11.1v
              4 - 11.1v
              5- 0
              6- float
              7- float
              8-11.1v
              9-11.1v
              10-0
              in POWER ON mode:
              1 - 12.75v
              2 - 12.75v
              3 - 12.75v
              4 - 12.75v
              5 - 0
              6 - ~ 70mv floats
              7 - 0
              8 - 3.3v
              9 - 0
              10 - 0
              Hope I did it right
              Waithing for the next steps
                You need to put down the pin names so we can easily see what is pin is for when looking at your result.
                • rprilutsky
                  • Oct 2020
                  • 7
                  Sorry - it was stupid of me. Here is the data as it is labeled on the legend on the board.
                  In standby mode:
                  1 - A13V - 11.1v
                  3 - A13V - 11.1v
                  5 - A13V - 11.1v
                  7 - A13V - 11.1v
                  9 - GND - 0v
                  2 - UD - 0v
                  4 - PWM-BLU - 0v
                  6 - PS_ON - 132mv
                  8 - GRND - 0v
                  10- GRND - 0v
                  in POWER ON mode:
                  1 - A13V - 12.75v
                  3 - A13V - 12.75v
                  5 - A13V - 12.75v
                  7 - A13V - 0v
                  9- GRND - 0v
                  2 - UD - 70mv
                  4 - PWM-BLU -3.1v
                  6 - PS_ON - 3.3v
                  8 - GRND - 0v
                  10- GRND - 0n
                    • 12206
                    • U.S.
                    Recheck pin 7.
                    • Diah
                      • Feb 2013
                      • 6399
                      99.9% your panel (LCD) edge boards had contact before with wet subjects. take look at it.
                      • rprilutsky
                        • Oct 2020
                        • 7
                        You are right, pin 7 is not 0v it is 12.7v
                        7 - A13V - 12.7v - my mistake
                        I inspected the edge boards with magnifying glass and I see no damage at all. Also this is my TV and I know what it never had any contact with water. It is possible that I damaged something dissasembling the panel (I replaced backlight LEDs), but I see no damage on the cables/boards.
                        WHat should be my next step?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Did you disconnect the ribbon cables from tcon to panel strip at the panel strip end. They don't look like they are inserted correctly since you can see the contacts on the ribbons rising up at the left-hand side (in your photo) away from the connector. Post #4, last picture.
                          Could just be the photo.
                          • CapLeaker
                            Leaking Member
                            • 8222
                            looks like bad tab bonds to me.
                              09-07-2024, 05:50 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
                              09-06-2024, 06:20 PM
