Another NextWave set-top box with bad caps on PSU and logic board
  • japlytic
    • Oct 2005
    • 2086
    The model is a TDR-3200, and the power supply is electrically identical to the TDR-3100 unit.
    See: https://www.badcaps.net/forum/showthread.php?t=3938 for more information.
    The TDR-3200 and TDR-3100 PSUs is of the self-oscillating type, with no current sensing resistor on the primary side .
    Since there was no primary side current sensing resistor, the +5V rail did not shut down when C15 (discoloured) was drawing excessive current, causing the failure of electrolytics on the logic board.
    All of the Samwha SD Series (85C) capacitors (except for the 400V unit) with low-ESR units along with the following caps on the logic board:
    30V rail: CB04 (tuner PCB), C404 (upgraded from 35V to 50V), C451 and C372.
    21V rail (unused): C456.
    Replacing the above capacitors fixed the problem, and fortunately, the tuner was not damaged by excessive voltage on the 30V rail .
    Should there be a quality recall on certain NextWave set-top boxes (power supply board)? I think so.
  • hardwareguy
    • Jun 2006
    • 405
    Re: Another NextWave set-top box with bad caps on PSU and logic board
    The whole thing just sounds bloody dangerous to me!
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • ohren
      by ohren
      09-08-2023, 05:24 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
      by momaka
      03-15-2023, 10:17 PM
