NextWave TDR-3100 bad caps on logic board caused by PSU
  • japlytic
    • Oct 2005
    • 2086
    The power supply circuit: http://www.eserviceinfo.com/download..._TDR-3100.html
    It was flashing on and off, making a whistling noise which went on and off.
    A few bulging Luxon GR Series capacitors on the logic board were removed, and this temporally fixed this problem.
    But the tuner voltage (typically 30V) was excessive (and rising! - but did not damage the tuner! )
    C15 in the power supply was too hot to touch, and it was found that the capacitors on the +5V rail (the only one being monitored) were faulty (but not bulging).
    So all of the capacitors (except the 400V unit) were replaced in the power supply, along with a couple on the logic board. They included the ones near the power supply connector and under the tuner (a bit difficult to get at! - with 105C units - an apparently hot area).
    The problem was fixed completely.
    The reason why the capacitors on the logic board failed is when C15 went bad, the 30V rail increased beyond the 35V rating of the capacitors on the logic board connected to the 30V rail, causing them to fail.
    One other thing: Why would such a supply have 30V connected to the optocoupler - where 3.3V or 5V is typically connected to the optocoupler.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: NextWave TDR-3100 bad caps on logic board caused by PSU
    Well, looks like the +30V O/P is the main O/P, the O/P regulated thru the feedback loop. It's a flyback ("ring choke") topology, where the "O/P inductor" is the transformer primary. The +5V and +21V O/Ps are semi-regulated, and the +12V is post regulated by a 7812 3-T regulator.
    PeteS in CA
    • japlytic
      • Oct 2005
      • 2086
      The +5V is well regulated, along with +12V coming through a voltage regulator.
      As I said before, the PSU only monitors the +5V rail.
      • PeteS in CA
        • Aug 2005
        • 3581
        Oops! I didn't look carefully enough. You're right, the main loop controls the +5V. The +30V that connects to the opto is also supplying current to the TL431. IIRC, a TL431 needs on the order of 5 or 10 mA for it to operate without oscillating, which makes using the +30V necessary.
        PeteS in CA
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
          by ohren
          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
          The models launched in 2018 and 2019 respectively....
          09-08-2023, 05:24 PM
        • Yanleb
          LG 60PK550 Logic Control Board EBR63450301
          by Yanleb
          Hi all, I just want to share the repair of my 60PK550-UA TV set.
          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
          C57: 3.30V
          C61:...
          07-20-2023, 12:38 AM
        • korben_dallas
          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
          by korben_dallas
          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
          MY QUESTION:
          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
          02-14-2024, 12:23 AM
