Lj41-04516a
  • crt man
    • Mar 2013
    • 106
    • England
    Lj41-04516a
    All does anyone in the UK, have a scrap board of the above, it is from a Samsung PS50Q7HDX.
    What I need is diode 5904 from the sub-board LJ92-01216B, I have looked for
    a circuit diagram but cannot find one down to component level for that board,
    I managed to source a complete one from the USA, and it works fine. There is a ticking sound coming from the sub-board, and after doing a side by side measure of components the above diode is O/C
    If anyone has one, I would be grateful or can tell what the diode is I need, so I can get this board to work and keep as a spare.
    Thanks.
    Alan.
  • crt man
    • Mar 2013
    • 106
    • England
    Re: Lj41-04516a
    Ok, I will go further afield (World) can anyone Identify the diode in question or does anyone have a scrap board that I can buy off them.
    Alan.
    • asr
      Finding replacement diode iPad Pro 3rd gen A1701
      by asr
      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
      07-09-2024, 06:24 PM
    • unimatrix93
      TV backlight zener diode
      by unimatrix93
      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
      The led strips has 9 6V leds.
      02-10-2025, 12:13 PM
    • Baste
      MBR3045CT and SR3045LCT Schottky diode testing help.
      by Baste
      Hello experts,
      Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
      Aneng ST182 Meter.
      Diode mode.
      MBR3045CT:
      Diode mode
      Pin 2-1 - 0.150v
      Pin 2-3 - 0.150v ...
      10-21-2025, 06:14 AM
    • NicRac
      monowheel repair,Is the diode the problem?
      by NicRac
      Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
      First of all, I am new here. Therefore I will shortly introduce myself.
      I am Nico and currently I study Physics.
      In my freetime I like to build and repair stuff. Especially big battery's.
      A few years ago I got myself an electric unicycle, monowheel or however you call that.
      The battery bms was broken so I replaced and resolder that. Nothing big.
      I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
      07-26-2024, 06:13 AM
    • dennis_elx33
      NO BODY MARKING Diode
      by dennis_elx33
      Hello Everyone,
      I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
      While compared to the reading of another diode from the next channel it won't read at reverse bias.
      Now the problem is; it does not have any body marking.
      So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
      What do you think is this diode?
      Can you please suggest what part number can i use to replace this faulty diode instead?
      Hoping that you...
      06-14-2024, 12:36 AM
