Vestel 17PW26-4 V.1
  • rafa805
    • Oct 2013
    • 19
    • Portugal
    Vestel 17PW26-4 V.1
    Hi all, so I had a friend who gave me a bad TV that is using this Vestel PS, and the TV is stuck at stand by, will not power.
    I took it a part and immediately saw a few bad capacitors, I replaced them all right away but no change.
    I've checked my output voltages, and the problem is 12V and 24V are 0, so i basically only have 5V and 3.3V.
    I've looked around in the forum for similar problems and checked everything I read that could be the issue but couldn't find anything.
    I've looked for shorts around the PFC controller chip, nothing there that I could find.
    All the diodes are ok, I couldn't find any shorts, so now I really don't know what else to check. To be honest I love electronics but unfortunately my troubleshooting skills need to be perfected and that's what I'm looking for, hope someone can help do just that.
    Thank you.
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Re: Vestel 17PW26-4 V.1
    Hi.
    what is mainboard name?
    https://www.badcaps.net
    • rafa805
      • Oct 2013
      • 19
      • Portugal
      Originally posted by arizanotlari
      Hi.
      It's a Vestel 17MB36-2 (020309)
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        in standby mode, chassis activated only 5V and 3V3. try turn-on set via rc or local keys.
        if led not blinking or other voltages (12V&24V) not regulated, rewrite SPI.
        If led blinking or other voltages regulated but cut off suddenly, check capacitors of U121 U144. There may also be a short circuit on the chassis
        Diagram : https://yadi.sk/i/dCNi9uSatOpTCA
        • rafa805
          • Oct 2013
          • 19
          • Portugal
          According to what you're saying I should now rewrite the SPI, the problem is I do not know what that is and I don't know how to do that, can you elaborate please?
            Can we see good clear straight shots pictures of the boards so we can see what we are dealing with?
            What is the power supply board number?
              • 20873
              vestel_17pw26-4 not sure if its the right one .
              • rafa805
                • Oct 2013
                • 19
                • Portugal
                Sure, here they are.
                • rafa805
                  • Oct 2013
                  • 19
                  • Portugal
                  Does anyone have any ideas?
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    With the mainboard disconnected from power supply jumper ST_BY to +5V using a 1K resistor. Then check for +12V & +24V.
                      If the schematic in post #7 is matched to this power supply board, the ST_BY (PS-ON) is active low, so if you run the power supply board by itself without any pull-up resistors, all the switched power supplies output should be present.
                      • rafa805
                        • Oct 2013
                        • 19
                        • Portugal
                        Well I can tell you that doing this in pins 11 and 12 I get 12.1V and in pin 26 I get 24.5V. what does this tell us? Main board issue?
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          So it looks like your power supply is working.
                            If that is the case, then the switched power supplies section are working, but the schematic does not match your board.
                            If you have all the board connected back together, what DCV do yo have on the ST-BY (PS-ON) pin when TV is off and when TV is turned on?
                            • rafa805
                              • Oct 2013
                              • 19
                              • Portugal
                              Let me rectify that. Those values where when I plugged the resistor between ST_BY and GND. Now I did it again but this time like you said the second time, between ST_BY and +5V and now I get 22.47 on pin 26, and on pins 11 and 12 it keeps changing constantly from 0 to around 5/6 volts, it almost feels like it's increasing and then suddendly it drops to 0.
                                I am confused, so if you put the resistor between ST_BY and GND you will get steady output from all the switched power supplies, correct?
                                But if you put resistor between ST_BY and +5V then the switched power supplies output are not on steady, correct?
                                • rafa805
                                  • Oct 2013
                                  • 19
                                  • Portugal
                                  Precisely!
                                  With the resistor in ST_BY to GND in pins 11 and 12 I get 12.1V and in pin 26 I get 24.5V;
                                  With the resistor in ST_BY to +5V I get 22.47V on pin 26, and on pins 11 and 12 it keeps changing constantly from 0 to around 5/6 volts.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    If the supplies are correct when ST_BY is connected to ground then that will be correc way. I had it the wrong way round. So Budm has given the correct method for testing.
                                    Edit
                                    Found some notes I made in the past.
                                    • rafa805
                                      • Oct 2013
                                      • 19
                                      • Portugal
                                      Edit
                                      Yes I've checked again and the values are the same, but the TV does not power. The local keys are touch and I think they.might be working because they beep when I press, the remote control I don't know whether it's working or not. Is there a way I can jumper something to force her to boot up?
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        Here is the schematic for your mainboard.
                                        I would check all the voltage regulators as shown on page 10 of 20 for the correct output voltages.
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • Adenitz
                                          Troubleshooting Vestel TV, has standby, but cannot turn ON
                                          by Adenitz
                                          I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                          Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                          Both boards are shown in the attached photos.
                                          What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                          12-27-2023, 03:43 AM
                                        • Bazilwrc164
                                          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                          by Bazilwrc164
                                          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                          If anyone can provide:
                                          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                          • Or a compatible EEPROM dump
                                          07-23-2025, 12:15 PM
