Vizio TV firmware reverse engineering
  • ARGO
    • Jul 2018
    • 31
    Hello!
    I'm trying to install mainboard from d50u-d1 into m65-c1 TV. They are the same, deference in panel settings only.
    I got access to factory menu but it doesn't allow to change panel settings.
    I have tried to replace MX25L3206E Flash chip from bad m65-c1 board to new d50u-d1, the TV turns on and works until power cycle. Then TV writes default d50u-d1 setting in flash chip and it doesn't work anymore.
    I need help with analyzing file dumps to find where are panel settings to modify them in original file.
    here are 3 files:
    2 original dumps from d50u-d1 and m65-c1
    1 m65-c1 rewritten by TV after first power cycle.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8213
    Re: Vizio TV firmware reverse engineering
    can we see some hi res, straight shot pics from the 2 boards? What is wrong with the original main board?
    • ARGO
      • Jul 2018
      • 31
      The problem is in BGA CPU. This is well-known problem for this series TV.
      You can make a search in forum, there are a lot of topics about it.
      • diif
        • Feb 2014
        • 6978
        • England
        You've checked there's nothing else that can store a model number on the mainboard ?
        • ARGO
          • Jul 2018
          • 31
          I think that panel settings in dumped flash because once I replace it with flash from old board TV turns on with settings from old TV and works until power cycle.
          • diif
            • Feb 2014
            • 6978
            • England
            It's usual for the settings to be read at startup from an EEPROM but they are written back from the NAND at power off.
            • ARGO
              • Jul 2018
              • 31
              this is not eeprom chip. This is SPI Flash and it has file system with files...
              DECIMAL HEXADECIMAL DESCRIPTION
              155892 0x260F4 CRC32 polynomial table, little endian
              159496 0x26F08 CRC32 polynomial table, little endian
              163592 0x27F08 CRC32 polynomial table, big endian
              196624 0x30010 gzip compressed data, has original file name: "display.bin", from Unix, last modified: 2015-07-31 01:13:31
              1376272 0x150010 gzip compressed data, has original file name: "database.TSE", from Unix, last modified: 2015-07-31 01:13:31
              2097200 0x200030 gzip compressed data, has original file name: "LogoB.bin", from Unix, last modified: 2016-06-04 04:19:26
              2228240 0x220010 gzip compressed data, has original file name: "display.bin", from Unix, last modified: 2016-06-04 04:20:17
              3276816 0x320010 gzip compressed data, has original file name: "database.TSE", from Unix, last modified: 2016-06-04 04:20:17
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8213
                Fact is that the main boards may look the same, the Tcon is surely not.
                As diif already said, are you sure that there is not another device of some sort that can store information?
                • ARGO
                  • Jul 2018
                  • 31
                  Have you read my post? If I replace flash IC from m65-c1 to d50, d50 turns on with m65-c1 settings and works until power cycle. So I'm sure settings stored in it.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8213
                    Umm... yaah... I can read... so good luck with it then... BYE!
                    • jjanssen7
                      • Nov 2012
                      • 252
                      I'm interested if you have success with this, I run into M65-c1 failure all the time... wonder if a similar thing can be done with other Vizio mains. So many BGA failures with the C1 series mains...
