I have a Panasonic wont turn on just flashed red lights any ideas thank you
tx-l42wt50b Panasonic wont turn on
Tags: None
Re: tx-l42wt50b Panasonic wont turn on
Service manual here https://www.electronica-pt.com/esque...a34-lcd-29737/
Blink codes on page 16. One blink is Backlight SOS - bad backlights.Comment
Tried it the power going to the av is up and down from 15.6v to 5v the screen flashes on for a second and goes offComment
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by gabrielA7Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
I saw that the room LED lights up only when the screen is connected, so quiet.
We have all the power supplies, even processor, 1.8V
One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
I suspect that there may be some leak in the processor.
Anyway, when I press the power, it... -
by madsoxGreetings!
Thank you in advance for your understanding, I am writing to you through a translator.
A Harman Kardon AVR171S amplifier was given.
The history of the machine is as follows:
It was faulty when I bought it, I want to fix it.
I replaced the HDMI switch and one of the DAC ICs in it.
After that it worked without a problem.
I watched a movie using the amplifier, and at the end the amplifier got really hot.
The cooling was faulty, I will fix this later.
I switched it to standby mode, waited for...-
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by letsfixthisHey,
I have been trying since 2 days to get this working.
The Acer VN7-791 had the 30 Minutes shutdown issue.
Therefore I desoldered the BIOS, cleaned the ME Region (with the Win-Raid guide) and Flashed the Version again.
It seems to have solved the reboot issues.
But unfortunately now I cannot turn off the computer anymore. It just reboots when I do it via Windows 10 or the Power Button. Only thing working is hard Reset via long press of the Power Button.
I tried to install an older Version of Mangement Engine... - Loading...
