VIZIO M50-C1, powers on, no backlight, no picture
  • gustagen
    • May 2011
    • 86
    Hi All! I've had several successes repairing TVs thanks to the helpful members here. I'm back today with another TV rescued from the curb.
    This is a VIZIO M50-C1. Previous owner posted it for free on craigslist with description 'powers on but no picture.' I was unable to get more information from them.
    When plugged in, the mainboard LED lights solid purple for 2 seconds, then changes to solid red. As the mainboard LED changes to red, the front LED lights solid white and fades to off over 5 seconds.
    When I press power on either the set or the remote, the mainboard LED lights solid purple and the front LED lights solid white. After 10 seconds it fades to dim solid white. After 7 more seconds it fades to off. At this point the set will not respond to power commands from either the set controls or remote.
    There is never any backlight activity, and I cannot see any picture using a flashlight.
    There is no change to the above when either or both T-Con connectors are unplugged.
    I noticed what seems to be a missing screw in the upper left of the main board. Perhaps it was never installed, or perhaps this set has been serviced before. The boards seemed equally dusty and I carefully cleaned them before taking photos. Most of the tape securing the wiring was in place and the connectors are all properly installed so I don't think the previous owner was recently poking around inside.
    I've looked over the boards and don't see any obvious faults. I've attached photos of the power, backlight, and main boards. I removed the metal shields covering the right and bottom sides on the main board. I can take more photos if needed.
    Thanks for any help you can offer!
  • neilc6
    • Nov 2015
    • 1550
    Re: VIZIO M50-C1, powers on, no backlight, no picture
    https://techhometravel.com/vizio-m43...-no-backlight/
    Vizio M series have BGA failures. Lots of threads if you search M43-C1 or M65-C1. Symptom is ON/OFF (backlight on signal) pin not going high (>2.5V).
    • gustagen
      • May 2011
      • 86
      Thank you, neilc6. I'm slightly familiar with BGA rework because a friend had a hot air setup for repairing XBOX 360 consoles years ago.
      I am currently out of town and away from my tools, so I'm waiting to borrow a DMM from a friend here.
      Out of curiosity, I removed the main board and was horrified by the state of the other side. What happened here?!
      I had previously noticed what I assumed was thermal compound in strange places on the main board and thought it was from sloppy assembly at the factory.
      • gustagen
        • May 2011
        • 86
        I've been looking at used mainboards for sale and many of them look as ugly as the one in this set.
        I'm also beginning to think this is not the original mainboard. I noticed earlier that this board has several connectors that go unused in this M50-C1, like CN203, CN211, CN212, and even an extra T-Con connector. Perhaps my board is a replacement from a larger M-series model?
        Replacements I'm seeing for the M50-C1 have solder pads for these connectors but they are unpopulated from the factory.
        I'll reinstall this mainboard and report back when I get a DMM.
        • gustagen
          • May 2011
          • 86
          I got impatient waiting to borrow a DMM, so I cleaned up the mainboard and reinstalled it. I found a suitable replacement for the missing screw in the upper left corner.
          I used a butane torch to heat the areas of the large black heatsink above the two processors, and the TV powered up! It's been playing YouTube for 15 minutes without issue, but we'll see how long this "repair" lasts.
          Thanks again for pointing me toward the common BGA issue, neilc6!
          • zape
            • Jul 2017
            • 176
            you'll probably have to do this every few weeks or months
            they say this "repair" method does not last long
            • zape
              • Jul 2017
              • 176
              I used a heat gun and a thermal sensor placed close to the heating area with some thermal paste
              Heated it up to 240C, kept it at that temperature for 10 seconds and it fixed the TV
              Here is the heating area
              • zape
                • Jul 2017
                • 176
                The "Fix" lasted for 1 month.
                had to redo it again, this time heated up both chips to 235-240C for ~1min
                will see how long it will last this time
                • kris42
                  • Oct 2022
                  This is an older thread, but I had the exact same issue with an M43-C1. After trying some other suggestions I landed here and followed your advice of heating up the section of the main board behind the heat sink. And it worked! My question is, why? And why isn’t it a permanent fix? Is the heat reflowing solder, or something else? Are there particular components that need to be reseated/resoldered?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    One/some of the solder balls have cracked, there is expansion of the balls due to heat and this makes a contact. It's not permanent unless you apply a suitable heat to remelt the solder balls.
                    • csmith
                      Vizio D50u-D1 Powers up no picture
                      by csmith
                      I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                      Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                      supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                      issue. Set will power up with remote but not power off....
                      07-11-2025, 11:52 AM
                    • afex
                      Vizio E371VL Powers on, no backlight or picture, will not power off
                      by afex
                      hello, I have a Vizio E371VL - the orange Vizio logo lights up while not powered on, changes to bright white when power button pressed but there is no picture.
                      There is no backlight, and I've done the flashlight test and cannot see any picture. The TV also will not power off using the button or the remote - I have to unplug the power cable to shut it down. The white light never fades out until unplugged. Its almost like its stuck in the powering up phase or something.
                      I bought a replacement mainboard and replacement power board. Neither have fixed the issue. It still...
                      11-08-2021, 09:20 PM
                    • sergio_av
                      Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                      by sergio_av
                      Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                      Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                      When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                      Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                      01-01-2025, 05:27 PM
                    • KYBOSH
                      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                      by KYBOSH
                      Saved this beast from the landfill this weekend.
                      Manfactured July 2013 in Mexico.
                      I love working on plasma TVs.
                      Its been a while but I was lucky enough to find 2 this week.
                      The TV powers on and stays on but no picture. Havent checked for sound yet.
                      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                      Will start troubleshooting tonight.
                      10-17-2024, 01:17 PM
                    • ggil44
                      Vizio M65-E0 No Picture, No Sound
                      by ggil44
                      Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                      09-03-2024, 08:30 PM
