Vizio E371VL Powers on, no backlight or picture, will not power off
  • afex
    • Nov 2021
    • usa
    hello, I have a Vizio E371VL - the orange Vizio logo lights up while not powered on, changes to bright white when power button pressed but there is no picture.
    There is no backlight, and I've done the flashlight test and cannot see any picture. The TV also will not power off using the button or the remote - I have to unplug the power cable to shut it down. The white light never fades out until unplugged. Its almost like its stuck in the powering up phase or something.
    I bought a replacement mainboard and replacement power board. Neither have fixed the issue. It still has the same behavior after replacing both boards. Those are the only two boards I see present in this TV, totally clueless what else could be going on here?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E371VL Powers on, no backlight or picture, will not power off
    A picture of the back of tv is worth a thousand words. T-con is most likely problem.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • nsab6464
      Vizio P502ui-B1E power light turns on, but no picture
      by nsab6464
      Hey guys,
      I have a Vizio P502ui-B1E with no display activity at all with the power light on. It broke in a very specific way, and now exhibits strange behavior when turned on (slow response to power off command, restarts every 90 sec, more below), so I'm hoping that someone with experience working on this TV can point me in the right direction.
      I already tried the 2 most common fixes with no luck:
      - Replacing the T-Con board.
      - Re-flashing the firmware on the U202 chip (from here: https://www.badcaps.net/forum/showthread.php?p=840012)
      Here's exactly...
      06-21-2019, 12:25 AM
    • Mgiffune
      by Mgiffune
      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
      I ordered a supposedly β€˜new' Tcon board this time, and
      06-09-2024, 10:28 AM
