BENQ G2420HD no back light after few sec
  • daran
    • Aug 2020
    • 5
    • United Kingdom
    I have two BENQ G2420HD. One is working normally the other went dark after 1-3sec of normal screen- before not able to see anything with flash light on screen
    I changed the the screen to the power board of the working monitor and screen worked fine.
    I went and hanged all the capacitors on the power board (dont have means to test capacitors) only have multimeter and soldering iron.
    Once the Capacitors were changed the screen comes on for 2-3 sec then goes dark- shining a light on it you can faintly see the display.
    I have attached some picture to gi with the issue......please help! I am not fully aware on how to test each component or what each component is in the power board so please point me in the right direction for me to read up on stuff
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: BENQ G2420HD no back light after few sec
    What number is printed on IC801, Q801, Q802, Q803 & Q804 on the underside of PSU.
    Can you compare the voltage on CN701 between the working and non working set
      https://www.badcaps.net/forum/attach...4&d=1596998731
      Is the negative leg of C701 soldered?
      • daran
        • Aug 2020
        • 5
        • United Kingdom
        @BudM- C701 is soldered
        @dick_barton- I assume you want to know the chips number?
        Q801 to 804 is A2790115
        IC801- 0Z9933GN,CC780J 30,1139A
        unless you mean the other side of the boards with the components on it.- see attached pics - will try and find CN701 and measure voltage -
        • daran
          • Aug 2020
          • 5
          • United Kingdom
          @budM- I read this case: https://www.badcaps.net/forum/showthread.php?t=40791
          and tested the transformer 1 and 2 points you refer to here on my board-
          Transformer 1- shows 2.06 at 20K reading
          transformer 2 - i get no reading.
          could this cause the 2 seconds to black and for the back lights to go off and not work?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            If the second transformer is not reading approx 2000 ohms as the first transformer then it does looks like the fault.
            • Diah
              • Feb 2013
              • 6376
              when the screen went off... what will happen when you press "wake" (power) bottom, did the screen cone again then off same time? in case the answer "YES" mean you have cut off signal at MB
              • daran
                • Aug 2020
                • 5
                • United Kingdom
                Hi guys cant seem to find a new inverter for this board!
                Was browsing this forum and came across this post (using LED board):
                https://www.badcaps.net/forum/showth...hlight=G2420HD
                Could I do the same but use universal CCFL inverter board? like this one:
                https://www.ebay.co.uk/itm/Universal...wAAOSwl4lbvlnD
                or
                https://www.ebay.co.uk/itm/Ultra-MIN...sAAOxy7S5SClL3
                Would just need some advice on where to solder the relevant wires to my board.
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  by sam_sam_sam
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • PNI E.
                  tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                  by PNI E.
                  hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                  02-20-2025, 08:36 AM
                • Alicat
                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                  by Alicat
                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                  Model number is TH-50PZ85U
                  Power comes on and the red power light stays on solid.
                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                  I also hear a few clicks.
                  I also think my parents said there was a thunderstorm and the TV failed after that.
                  Section 6 in the service manual talks about power and no screen,...
                  10-30-2024, 10:09 AM
                • ivtec
                  model:ONN 100005396 roku tv black screen no back light/
                  by ivtec
                  hi guys i have found model:ONN 100005396 roku tv is dead just stays black screen,no back light standby is red,when press ok menu buttom it blinks i can hear the roku sound .
                  I tried resetting with the remote and power and reset button no luck.
                  I wonder if the backlight burn out?
                  I don't have the original remote i have another roku box remote but has no power button, do i need remote power button to turn on tv?i thought when you plug it in it boots like any roku box?
                  any ideas, tomorrow i'm going to measure some points on the board.
                  10-09-2021, 04:42 PM
