no backlight supply volts hisense ub50ec591uwt
Re: no backlight supply volts hisense ub50ec591uwt
open the metal shield of the T_CON post very clear close photo of it... also you have on it SMT fuse test it black probe on chassis if you have 12V. on both side of the fuse.
BTW:
if you confirmed there are 12V on both side of the T_CON fuse.. please put every things in place and turn on the TV, black probe on chassis and read all the voltage as they are listed over here
PWM2 --
SW ---
12V ---
STB ---
16V ---
3DS ---
3DE ---
PWM3 ---
the 12v feed to tcon is good on both sides of fuse .
the psu o/p plug has 10 pins ,not as shown printed on the side of the board next to the plug which is for a 15 pin version of the panel
i am posting a pic of the voltages measured on the plug
basically its ;pwm2 2.9v switching
sw 3.5v switching
sby 3.8v switching
12v supply not switching
16v supply 19.2 not switching
the only thing thats bothering me is the original leds need a higher voltage to light compared to the ones ive replaced which will light with my dmm on diode test
still only 3 volts backlight feedComment
While you are doing that test could you also check Pin16 of the LX2901. Votage should be a regulated 5.25VWilling to help but I'm no expert.Comment
i was told it just failed and the backlights all looked untouched ,if the psu was the wrong one you would assume that the main board would have a plug with missing lead also the main board does not have any spare sockets for any other plug ,so from this i assume its the correct psu .
the two pins with the 20v on, are joined on the print of the psu ,and i wonder why its not 16v as shown on psu , the 12v is ok shown as 12 v on psu.
if i unplug the main board and fit jumper between SW and STB surely the psu cant start up as both these pins read 0v at switch on and only recieve volts to turn on from main board ? or am i missing somethingComment
16v ok 12v ok , sadly still no bl voltsComment
Pin 1, VCC can accept a voltage of 10V to 27V so the supply to the IC is fine.
Pin 2, Enable input is also fine at 2.4V so the IC is enabled.
Pin 16 is a 5.25V regulated supply internally generated from Vin and is the supply voltage for the circuitry inside the IC.
I would say that it looks like either the IC is faulty or any capacitor connected to pin 16 needs to be checked.Attached FilesLast edited by dick_barton; 08-05-2020, 04:06 AM.Willing to help but I'm no expert.Comment
this tv has two led strings im wondering if there resistances at switch on are compared within this chip it would then fail to produce this voltage on pin 16 although all leds test fine perhaps theres a difference in the replacements i have fitted compared to the originals?Comment
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM -
by frannyjunkSo I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
TIA. -
by phuzzydayThis was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
(All the Electrolytics are brand new.)
I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out... -
by ojmcBackground:
- Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
- I replaced all 6 of the backlight LED strips with these replacements: amazon
- The TV worked again perfectly for ~2 weeks.
- After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
Assuming...7 Photos - Loading...
