Sony XBR-65850F No Picture (Backlights/Audio Okay)
  • philtvman
    • Jun 2016
    • 94
    • America
    This is a similar case to this thread
    Picked up this unit from a guy who said he took it to a repair shop and they weren't able to fix it. The TV turns on, backlights and sound both work, but there is no picture. The thread linked above had an issue with a shorted MLCC on one of the panel driver boards. I went through them all, and I couldn't find anything shorted (unless I was measuring them wrong).
    All voltages going from the PSU to the TCON/Main look nominal. TCON is getting the 12V and it's passing through the fuse just fine.
    One thing I noticed is that it looks like there may be a diode that is missing on the far left (looking at it from the back) driver board...D104. There is a matching spot on the right side (D204) that has the part still in place. I have no idea if it is the exact same part, but I would tend to believe it probably is. It has 6514P 1829 marked on it. Unfortunately, I am having zero luck finding this part online anywhere.
    Anybody have any advice?
  • budwich
    • Jul 2015
    • 3097
    Re: Sony XBR-65850F No Picture (Backlights/Audio Okay)
    goes look like someone "modified" the board with a soldering iron ... :-)
    Try disconnecting the tcon to panel cable going to that side with the missing component and see if that changes what happen on the screen.... which is?
    • philtvman
      • Jun 2016
      • 94
      • America
      Disconnecting that side still has no picture unfortunately. The disconnected side is black obviously, but still no picture on the other side.
      • budwich
        • Jul 2015
        • 3097
        "normally", if one disconnects the tcon to panel cable, the result is a white screen (although some sets display black).
        although you say the voltages from the PSU to the main / tcon look "nominal" can you list the labels / pins and then post those measurements for each... do this for the set in standby / power plugged in and then again with power ON / set running so the forum can see what you are saying in "more words"... :-)
        further, there are a number of voltages labeled on the tcon (left side of your posted picture). Then again you should carefully measure and post with the label... these may indicate what area is missing / not right to get a display.
        Lastly, also post a picture showing the whole back with connected cards so the forum can see how things are connected.
        on the post that you referenced, post 99 appears to point to the area for the resolution. Based on that, you should be looking at either a short OR open.
        • philtvman
          • Jun 2016
          • 94
          • America
          I have attached a picture of the back and of the voltages. What is the best way to check the MLCC capacitors for a short or open? I went through them all with my multimeter in continuity mode. Would the apparent missing diode not be a cause for the TCON not processing correctly?
          • budwich
            • Jul 2015
            • 3097
            good work. Those values look OK. As mentioned there are voltages on the tcon that maybe of value... as read in the referenced link, feakaftr8 checked those also.
            Certainly a missing component is an issue... assuming you know that the component is indeed missing. Manufacturers don't always populate every labeled device / component. Hopefully, perhaps someone will have info on that diode.
            From the posted picture of the back, another test is to keep all the cables connected but disconnect the "U" ribbon that runs between the bottom edge boards. Do this one at a time and see if that changes anything.
            Also, it appears, like the linked reference, that there is some IC differences between the right and left "half" of the panel on those edge boards.
            • philtvman
              • Jun 2016
              • 94
              • America
              Sorry to be ignorant, but how do I go about testing the voltages on the TCON board. I did notice that freakaftr8 was able to measure the voltages going from the TCON to the panel, but I'm not sure how to do that.
              • budwich
                • Jul 2015
                • 3097
                there are labels and circuit board "points" where those "label voltages" can be found.
                somewhat related to this. You indicate a difference between right and left bottom edge boards in terms of a missing component. You can check the voltage (to ground) on the contacts and compare them from each side. Might indicate something.
                • philtvman
                  • Jun 2016
                  • 94
                  • America
                  Sorry, I feel blind. Where are the labels?
                  • budwich
                    • Jul 2015
                    • 3097
                    As I indicated on the left side of the tcon... things with "Vxxxxx" are of interest.... eg. vcom1, vcom2, etc...
                    • philtvman
                      • Jun 2016
                      • 94
                      • America
                      Attached is a closer up picture of the VCOM, VST, VGH lines, where exactly are the test points for them? I thought it would have exposed test pads.
                      There is also some variation between what happens when the driver boards are unplugged, I've tried all different variations. Regardless of what I do though, there is never a partial image. Attached is the result of unplugging the driver boards.
                      Thank you for your help, I really appreciate it.
                      • philtvman
                        • Jun 2016
                        • 94
                        • America
                        What is the best method for testing MLCCs? Since this is a common failure point for this symptom.
                          Use Ohm meter to look for MLCC that show low resistance (<100 Ohms) readings in both directions.
                          • budwich
                            • Jul 2015
                            • 3097
                            I see that your "observations" might have been a bit different than earlier. :-)
                            It would appear that potentially there is an issue associated with the tcon 1 / 2 side of the panel.... maybe as it is black rather than white.... the disconnect test is a "gross test" so it is relatively open to interpretation.... but maybe helps with further focus. As I suggested earlier, there are "U" type ribbons interconnecting the bottom edge boards. Leave all the tcon cables attached and do a "disconnect test" with those "U" cables and see if anything changes.... look closely and report the outcome on the display result.
                            • chrismurphy
                              • May 2014
                              • 251
                              • australia
                              Main board problem ,common on this set
                              • philtvman
                                • Jun 2016
                                • 94
                                • America
                                Correct, I had only disconnected the 'missing component' side at first. The picture I attached showed what resulted from the unplugging of the 'U' cables (all variations). I've attached another result with a diagram. Per the linked article though, it seemed that if there was a short or open somewhere on the driver board that the TCON in these sets won't power on completely.
                                I went through all the MLCC with an ohmmeter. The smaller ones all tested either 2-4k Ohm and the larger ones were all OL.
                                • philtvman
                                  • Jun 2016
                                  • 94
                                  • America
                                  How can I be sure of this?
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    ok ... sorry I misread previous post with numbers... I thought they referred to the tcon cabling and not the "u" cables. hmmm... interesting about the results. As mentioned, was expecting some form of white.... but again, perhaps I misunderstand what the chart is saying. Can you post a picture of the screen for the ones that show white?.... I think I understand what you are indicating but just want to make sure. Further, what is the difference between black, grey and white?
                                    In terms of labeling, there may not be "shiny test points" but the labels are aligned with where tracks / component circuit tabs are most likely to be associated with the label. You can "guess" a bit and use your meter (on continuity and board unplugged) to follow paths to confirm.
                                    • jostewcrew
                                      • Mar 2020
                                      • 79
                                      according to the service manual, its a tcon or panel issue.
                                      • philtvman
                                        • Jun 2016
                                        • 94
                                        • America
                                        Was finally able to grab the TCON voltages, see attached.
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
                                        • tree5656
                                          diagnosing sony XBR-75X900H. NO PICTURE
                                          by tree5656
                                          This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                                          11-09-2023, 04:55 PM
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
                                        • ronni
                                          Sony KD-43XE8005 with sound, backlight, no picture
                                          by ronni
                                          I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                                          When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                                          Removing the LVDS cable results in...
                                          12-01-2022, 08:44 AM
                                        • sordids999
                                          SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                          by sordids999
                                          Hi
                                          Really stuck on this TV
                                          I'm thinking it's a bad screen ?
                                          Voltages all seems good
                                          Tcon 12v ok
                                          Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                          even tried the tape trick still no luck
                                          Thanks...
                                          05-12-2025, 10:36 AM
