Re: Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lig
OK, so the 200F reading would be normal for this chip then under this circumstance? In that case, perhaps my problem is somewhere else on the board but not necessarily showing up as a thermal tell tale? Also, why do you think the twin IC next to it, also an AY7397, is showing about half the heat signature of this one?
If its not the chip, would you say the most likely issue is the ballast? Or alternately, the replacement lamp I bought is bad? Its brand new, although not OEM and about 1/3 the cost of OEM. But if the issue is the lamp, I would expect the blink code to point to lamp replacement, not internal projector error, so perhaps signs pointing to ballast failure, explains why the lamp not lighting and explains why the chip gets hot due to lamp not lighting? But not an odd thing that this is the only chip on the whole board to react thermally to lamp not lighting?
Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
AY are DC to DC PWM (Pulse-width modulation) step down.
with easy language of my...the boot didn't receive signal LAMP ON, it will not step down. it keep on high pulse ( FAN High SPEED ) ( ERROR BLINKING ) this why they become warm.Last edited by Diah; 08-06-2020, 10:38 AM.Leave a comment:
UPDATE: I finally got around to taking FLIR shots of the motherboard during the failed boot sequence. It appears that an IC is getting really hot, a little over 200F. Here are the pics if someone can offer suggestions based on the thermal pics:
Suspected failed IC is the bottom right hot spot:
IC4706 in the pic below is >200F
IC4796 has marking AY7397 but I could not find a match on mouser.com:
IC4706 and IC4707 appear to be the same but one is > 200F and the other is a little over 100F:
The circuits are in the middle of the pic here and appear to be twin circuits with same components:
if it was stored where its damp like mine was it could be corrosion on the integrated circuits pins ... fixed be a damn good scrubbing with soapy water then hose down with isa then a good blast with compressed air .Leave a comment:
Well I did the firmware update and still get the same blink pattern. I guess I'm going to pull the cover and check the MB with the Flir.Leave a comment:
in this case yours IRIS not the issue at all, EPSON HW and chips on boards very stable never faced problem with them at all... you my have 2 possible issue
1- The ballast or lamp
2- some how corrupted firmware via firmware upgrade in wrong way.. ( you can due i again ) as i think you have boot on the epson which can connect to PC and have access to NAND for firmware upgrade & refreshLeave a comment:
BTW yesterday i got epson EB 824/h and it was in condition when you press power it lid blinking green for about 1 minute then it change to orange blinking together with TEMP and LAMP,and the FAN speed went high. it was the IRIS stuck at close option and don't move , there was no issue by move it with hand. the sensor surface was blind by dust cleaned it with air spray then projector run again quite and smoothly.
I'm going to check the iris but I'm starting to think its NOT dynamic iris issue since there is a specific LED blink pattern for that and I'm not seeing it (flashing STATUS, flashing LAMP and flashing TEMP). I'm thinking a chip on the motherboard has fried or shorted component. Just haven't had a chance to put it on the bench (my kitchen counter) to do a FLIR camera test yet.Leave a comment:
mean never turn on the set on with out lamp and the lamp cover switch should be switch correct
BTW yesterday i got epson EB 824/h and it was in condition when you press power it lid blinking green for about 1 minute then it change to orange blinking together with TEMP and LAMP,and the FAN speed went high. it was the IRIS stuck at close option and don't move , there was no issue by move it with hand. the sensor surface was blind by dust cleaned it with air spray then projector run again quite and smoothly.Leave a comment:
1- yes if the iris stuck at close position will give the same fault. if its stuck at open it will display warning then go to shut down same as you have right now ( take out the IRIS from it place.. INSPECT / CLEAN / move it with hand many time / Oil the shift of them ) then put them back as they should )
Not quite sure I understand what you are saying here.Leave a comment:
Thanks. Yes, I've tried with lamp cover securely screwed and then when testing for strike with lamp cover removed, I've shimmed the cover switch closed. The projector will not even light up if that switch is open.
The light sequence remains unchanged wether there is a lamp in or not. I first get 4 blue status light blinks when the cord is plugged in, then when I push the power button, it starts the blinking blue status light for about 4 minutes (apparently as it goes through its checks and to boot sequence), with low active fans heard. Then after about four minutes it appears to go into its failsafe, the power light goes off, the shutter closes, the fans go into overdrive and the blink pattern is flashing blue status light and flashing orange lamp light.
My guess would be that you either have a bad second bulb or ballast as the most likely source for the issue. Not sure that the system can readily tell the difference between a bulb and ballast as the two work in "tandem" to cause the "light function".
In terms of electrical tests, perhaps the boards have some labeling on them for basic electrical points (ie. input voltage, standby, etc) that can be checked.Leave a comment:
I'm thinking one of four issues perhaps:
1) Stuck dynamic iris (would fans operate if iris is faulty?)
2) Ballast failure (would fans operate if ballast is faulty?)
3) Motherboard failure (one or more component on the MB is shorted). I have a Flir camera charging now to check for thermal hotspots/shorts during the boot startup sequence.
4) Both of my lamps (one is brand new but not OEM) are faulty, but I think this a long shot because I'm not getting the correct blink LED for lamp failure. I'm getting blink pattern for "internal projector error", which points more to issues 1-3.
1- yes if the iris stuck at close position will give the same fault. if its stuck at open it will display warning then go to shut down same as you have right now ( take out the IRIS from it place.. INSPECT / CLEAN / move it with hand many time / Oil the shift of them ) then put them back as they should )Leave a comment:
you need to tear it down, and first things need to check 2 points
1- the mechanical of the lens cover. on the boards there are micro switch with 3 gate. exam them manually with beep ton DM.
2- there are small FAN which blew air on the 3LCD ( not 3LED as you wrote ) if there no move or slow move of it will cause error.
On point number 2, yes the lamp fan is operating fully. I left the cover open and manually propped the switch to observe the fan operation during the attempted startup with and without a lamp.
4) Both of my lamps (one is brand new but not OEM) are faulty, but I think this a long shot because I'm not getting the correct blink LED for lamp failure. I'm getting blink pattern for "internal projector error", which points more to issues 1-3.Last edited by vestaviascott; 07-29-2020, 08:00 PM.Leave a comment:
inspect the lamp cover drawer and area. Manual says the bulb will not light if the drawer is not properly installed. This indicates that there is a lamp drawer switch or equivalent (which is normal for most projectors). Actually, that is a test... what happens with the light sequence if there is no drawer in place? Similarly, others test like that can be done...eg. disconnected lamp and resulting indicators.
The light sequence remains unchanged wether there is a lamp in or not. I first get 4 blue status light blinks when the cord is plugged in, then when I push the power button, it starts the blinking blue status light for about 4 minutes (apparently as it goes through its checks and to boot sequence), with low active fans heard. Then after about four minutes it appears to go into its failsafe, the power light goes off, the shutter closes, the fans go into overdrive and the blink pattern is flashing blue status light and flashing orange lamp light.Leave a comment:
As suggested, do not expect to measure voltages at the lamp as the ballast puts out "over voltage" during the strike to start the bulb... very high voltages.Last edited by budwich; 07-29-2020, 07:51 AM.Leave a comment:
2- there are small FAN which blew air on the 3LCD ( not 3LED as you wrote ) if there no move or slow move of it will cause error.Leave a comment:
dont even think about measuring lamp voltage . it will blow your meter up like mine did .Leave a comment:
Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
Here's what happens:
1) Power on
2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
3) Blue status light flashes for appx 4 minutes
4) Blue power indicator light goes off, lens cover motor engages and closes the lens cover, blue status light continues flashing and orange lamp light starts flashing and fan kicks in high gear
5) After about 2-3 minutes, the fan goes into low speed and nothing else happens
I've tried reseating the lamp, bought a new lamp and tried it and no joy. I've also removed the lamp cover to observe the lamp during the startup sequence and it does not light.
I'm thinking next steps are to check that I'm getting power to the lamp via the two pins the lamp connects to, but not sure if that's even possible given the high voltage required to strike the lamp. What would next steps be?Last edited by vestaviascott; 07-29-2020, 06:16 AM.Tags: None
Hi guys gooday i have a Epson VS250 Projector that turns on and is also being recognized and detected by the computer when i plug the hdmi cable.The only issue the projector lamp is not working .Are these lamps repairable ? Or i should just forget repairing the lamp and just buy a replacement. Thanks...
by narfhi all,
first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
what i've found so far:
- the PSU does its job and supplies 12V to the mainboard via the connector.
- shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
- not far away, there's the first cap with a resistance of 0.7 ohms.... -
by magnetepazzoHi Guys i have this projector emp-x52 when power on the fan spin and lamp go on but after few seconds lamp go off and led temp flashing with fan at maximum speed. I have check the 2 termal temp but are good are 12.51 Kohm. Have suggestion for me ? TKS
by EVAN STUARTSHallo guys I need some help with this Epson projector I turn it on but it stops at power light it does not switch on
Pliz help guyz -
by hardboxNeed some idea of where to start to fix this projector. According to the user manual, when the temp and lamp lights are flashing there is an internal problem which doesn't give me much to work with. Need some input. The fans run for like two seconds when attempting to turn on then goes straight to the error code. Since it's not a lamp, fan or temp error, I'm leaning towards the power supply.
https://www.manualslib.com/manual/74...page=80#manual - Loading...
