VIZIO E50-C1 Backlight Driver circuit
  • high-tech
    • Sep 2010
    • 197
    Hello Everybody, I have a good one. I got this TV a couple weeks ago and it had about 80% of the LED strips burnt out, So I ordered a replacement set of strips and installed them. This tv's backlight array will stay on even with several burnt led strips, I found that odd. Anyways I get this tv back today with 2 strips not burning and one strip dimmer than the rest. I smell something burning and it turns out those little chips in a circle around the little square controller chip, there are 6 of them, two of the six are so hot I burnt my finger. the numbers on the chips are top row 4892 and under that is GA4Y2C. I typed those into google and EBAY and nothing comes back on the search query... I didn't get the chance to do any voltage testing, it all happened so fastand I dont want to turn the set back on causing further damage. I want to replace those chips, but I can't find out what they are.
    Re: VIZIO E50-C1 Backlight Driver circuit
    Those are MOSFET AO4892.
    They are PWM Controlled for maintaining constant current through the LED's. If you have some shorted out LED's then the MOSFET will get hot.
    I do not understand this:
    "So I ordered a replacement set of strips and installed them. This tv's backlight array will stay on even with several burnt led strips, I found that odd. Anyways I get this tv back today with 2 strips not burning and one strip dimmer than the rest"
    Are you saying after replacing the all the LED strips and now some of them do not light up? But picture #1 show all LED strips are on.
    • high-tech
      • Sep 2010
      • 197
      Hi budm, I took that picture of the led strips when I first installed the replacement led strips. The second led strip from the top on the left was slightly dimmer than the rest... When I took the panel out this time that dim strip is now barely lit and skip two other strips below it s and the next one is burnt out... I visually inspected the harness and can't find a problem. The plugs at the led strips are so small I can't meter that end of the cable. I'm new to all this led crap. I've been gone from this tv repair scene for about 5 years, I've got some catching up to do!!! The dim strip is dim when I plug another strip in that harness, so there is nothing wrong with the dim strip.
      • howardc64
        Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
        by howardc64
        Problem
        Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
        Model & Board Pics
        Conflicting Spec
        Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
        https://www.shopjimmy.com/vizio-gj-2k1...
        10-10-2024, 01:16 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • Yanleb
        Vizio M70-D3 4K with dark spots backlight issue
        by Yanleb
        I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
        On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
        I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
        03-22-2022, 01:06 AM
      • osrex
        LED DRIVER KEEPS DYING
        by osrex
        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
        i have no datasheet at all for the LED lights, all i have is its length.
        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
        05-05-2025, 03:36 PM
      • jinu_j
        LED driver circuit. Burnt Resistors
        by jinu_j
        Hi Folks
        This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
        Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
        But i have some queries on this circuit
        1. The resistors that burnt to crisp...
        08-26-2020, 01:24 AM
