Philips 47PFL4606 No Power Fuse Keeps Blowing
  • trunks81
    replied
    Re: Philips 47PFL4606 No Power Fuse Keeps Blowing
    tested again waited like 15min an then connected the board.
    only the boosted voltage drops from 410 to 312
    and the voltage on C946 stays at 9,91 no drop of climb
    5v is still present
    replied
    Originally posted by trunks81
    Checked C946 again and that one does not climb to 15v it stays at 9.91V
    If you did see 410VDC on the main cap then it did go up to 15V and allow the PFC to startup to produce the Boosted Voltage on the main cap, but now it goes back down to 9.9V.
    You did test by running the power supply board by itself and 1K force on resistor in place, correct?
    What happen if you remove AC from power board for 5 minutes, have the meter connected to the main filter cap then plug the main board into AC outlet again and see if you will see 410Vdc on the main cap.
    BTW, the 5V standby power supply is still putting out 5V, correct?
  • trunks81
    replied
    replied
    put R947 back in and i see an strange thing happening with the boost
    its start at 410 and goes back to 312
    That means the Voltage on C946 did go up close to 15V so the PFC starts up, but then PFC drops out.
    Now we need to find out why.
  • trunks81
    replied
    replied
    Lets put R947 back in place and see if the PFC Boost Voltage will be present.
  • trunks81
    replied
    Hello Budm
    No i did not replace D916 because it measered oke,
    replied
    I have a question, did you replace D916?
    replied
    Both IC901&IC902 measure to ground high ohmage
    We remove R947 for testing so those two IC's are not drawing any power from C946 so Voltage on C946 should be close to 15V, but it is not.
  • trunks81
    replied
    replied
    Readings where done when 1K resistor is connected.
    red is without and green is with
    OK thanks, more thinking to do.
    So it jumps from 11.5V to 14.1V when 1K is connected which is correct because the standby also jumps from 4.6 to 5V, but the two bad boards are not jumping up to 14V.
  • trunks81
    replied
    replied
    BTW, do you remember this thread of the other 47" that we fixed, you took the Voltage readings for me after the board was fixed?
    Do you remember if the Voltage readings of Q907 was done using 1K resistor or it was done when the main board is connected?
    This thread here: https://www.badcaps.net/forum/showthread.php?t=86061
    https://www.badcaps.net/forum/attach...6&d=1594984130
  • trunks81
    replied
    When i connect mainboard in the tv iam getting 11.18V on C946
  • trunks81
    replied
    i did swap everthing back to normal, the 37 inch board i did send out for repair by accident.
    replied
    i did swap T803 from the 47 to the 37 inch, And powered the 37 inch with the other T803
    So did you swap the transformer back so everything is back to original condition?
    T803 is inverter transformer, it will not cause low Voltage at C946, beside, we remove the resistor that feed the switched VCC for the PFC IC and the 12V/24V SMPS IC.
    BTW, so did you buy the 37" replacement board or you sent the board out for repair?
  • trunks81
    replied
  • dick_barton
    replied
    He mentions swapping T803 in one of the threads so I wonder if this is a link to the problem.
    replied
    Originally posted by dick_barton
    OK, I see, no boost without those components and I see that you are still working on finding the missing 15V
    I had him remove R947 (and other not needed parts for the STBY 5V power supply to run) for now so there will be no PFC and SMPS IC loading down the 15V power supply from AUX winding of the STBY power transformer.
    Right now he has only about 10V on C946 instead of 15V like the other 47" that I helped him fixed. The IC's need 12.5V startup Voltage for them to run.
    He also has only about 10V on c946 of the 37" board for the 37" TV he is working on in the 37" thread and that is why he does not have PFC boosted Voltage on the 37" TV either..
    If we can figure out why we are only getting only 10V and fix it then we can fix the 37" board at the same time.
    What does not make sense is that 5V (4.6V in standby mode) is at 5V when 1K force on is present, so the 15V winding should also be 15V but it is not.
    The other 47" board for the other TV (we do not have that TV any more) that I helped him fix shows 15V as it should but not these two boards.
    The 37" board that he sent out for repair is also not fixed either. I wish I have the board in front of me instead of trying to do remote troubleshooting due to some time we get wrong data.
    And now we just found out that there is solder bridge on pin 5-6 of the PFC IC, frustrating, I am glad I did not have him put the R947 back in yet..
    Once we get he 15V back, he will have to check 12V/24V section real well too for any solder bridge before putting R947 back in place.
  • dick_barton
    replied
  • Dannyx
    UC3842 Power Adapter Blowing Fuse
    by Dannyx
    Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
    Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
    12-05-2023, 12:06 PM
  • Tips
    Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
    by Tips
    Looking for some assistance please.
    Trying to repair a PD27AOQ samsung power board.
    Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
    Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
    Testing it the fuse blows immediately power is turned on.
    diodes dm852 and dm853 test as shorted when in the board but fine when removed.
    any assistance, guidance would be appreciated.
    04-11-2024, 11:24 AM
  • RogerH58
    Samsung 46" TV LE46B530 blowing fuse
    by RogerH58
    I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
    I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
    I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
    06-10-2023, 10:27 AM
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
  • simwalsh
    Philips 47PFL4606 Powers on, works normal then powers off after a minute
    by simwalsh
    I am new to this forum and have searched for some answers with problems similar to mine.
    Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
    It sounds like a power supply issue?
    I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
    12-04-2023, 04:03 AM
