Firmware Hisense 55B7100UW
  • Ettie
    • Jul 2020
    • Zimbabwe
    Hi all
    Our TV screen is stuck on the Hisense logo and then it reboot itself.
    After googling it came up we need to download the latest update on a USB and a certain process to follow but I cannot find the needs file for our model.
    Does anyone know where I can find it please?
    Ettie
  • patrax
    • Feb 2014
    • 33
    Re: Firmware Hisense 55B7100UW
    Contact Hisense thru email they will send you a link for the firmware for your model. Its impossible to find it on any countries Hisense website. Believe me email is the only way,took them about 4 hours to reply instead of the 8 hours I wasted trying to find it on the web.
    • nomoresonys
      • 12331
      • U.S.
      That's a plus for Hisense, most of the "major" brands won't even reply.
      • Diah
        • Feb 2013
        • 6592
        you are lucky MB of this series can accept any size of many kind hisense even the B8000 and the new Q series... this one reason they just gave link on request valid for 24 hours only
        • Dragunov
          Need firmware for HISENSE 40A5NQ
          by Dragunov
          i need firmware for HISENSE 40A5NQ so i can flash it via USB...
          Tried via USA website but it doesnt accept my serial number TV was bought in croatia.
          Remote works only to power on tv and after that i cant select firmware update or anything else...
          07-07-2025, 01:33 PM
        • slavetothesound
          HP ProDesk 600 G6 Mini BIOS unlocked - now EC can't find valid firmware
          by slavetothesound
          I Used a T48 and RCUnlocker to remove password from the BIOS on a previously fully functional HP ProDesk 600 G6 Mini. Everything went very smoothly and I was able to boot the machine and install an OS. I then unplugged the machine and put it on the shelf for a week.
          Now when I boot the machine, it does not POST. It plays 5.2 beep codes which are interpreted as:
          I read the firmware with the T48 and it is different than what I flashed to it, so I flashed the unlocked firmware that I had saved. No change. I could use some advice on next steps to take.
          04-12-2024, 10:05 AM
        • Coldblackice
          GoXLR-Mini.Possible to extract this firmware? Or find its datasheet?
          by Coldblackice
          I'm trying to extract firmware from a GoXLR-Mini
          https://www.tc-helicon.com/product.html?modelCode=P0DI7
          I know it's not ideal, but I'm trying to extract the 64MB firmware without removing the chip. I've done this before, but I realize it's a case-by-case thing. Unfortunately, it seems this board's layout results in it getting powered by my SPI tool (Buspirate), failing extraction.
          I believe the issue is the flash chip's HOLD pin unable to get pulled high, as the current for that pin dissipates elsewhere in the circuit. When I try to pull the HOLD pin...
          02-25-2022, 06:27 AM
        • mon2
          Hisense 55Q9G Android reset / factory firmware reload
          by mon2
          Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
          After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
          01-03-2024, 10:25 AM
        • howardc64
          HiSense 65H6510G no boot
          by howardc64
          TV standby light flash once after plug-in AC power. Then silent. No backlight, no LCD image on flash light test, no SPDIF light.
          All PSU voltages to main looks good (12v, 20v (label says 18v but is 20), standby voltage) Probing main board shows what appears to be a DCDC converter (MSH6103A can't find datasheet) providing 5v, 3.3v and 1v. 5v present to the standby light power switch board.
          These HiSense TVs appears to have lots of firmware corruptions that takes out the main board either through smartTV use or firmware update. Used main board...
          03-29-2023, 12:52 PM
