Need firmware for HISENSE 40A5NQ
This topic has been answered.
  • Dragunov
    • Nov 2013
    • 49
    • Croatia
    i need firmware for HISENSE 40A5NQ so i can flash it via USB...
    Tried via USA website but it doesnt accept my serial number TV was bought in croatia.
    Remote works only to power on tv and after that i cant select firmware update or anything else...
  • Answer selected by Dragunov at 07-08-2025, 12:10 AM.
    lotas
    • Jan 2016
    • 4761
    • Russia
    Most likely, the TV has lost synchronization of your remote (this happens with HISENSE). Turn on the TV via the remote, when the TV loads, press both buttons on the remote at the same time "Volume +" and "Ok" and hold them for a while, the remote should register your TV again.
    • lotas
      • Jan 2016
      • 4761
      • Russia
      • Dragunov
        • Nov 2013
        • 49
        • Croatia
        Thanks mate its solved... My man!
        • lotas
          • Jan 2016
          • 4761
          • Russia
          Ok!
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • TheUser
            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
            by TheUser
            Hello to everyone ,
            This is my first post here, and i would like to share with you a small story in case you can help me.
            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
            02-10-2024, 02:07 PM
          • Jackching
            Hisense 65R6107 remote sensor
            by Jackching
            Does anyone know if there is a repair for the remote sensors for these televisions? It only seems to work when it wants to. I tried a different remote and also tried factory resetting the TV. I find if i go close to the sensor that it'll work but outside 2 feet it wont.
            10-30-2023, 11:35 AM
          • gurj1979
            Ubiquiti firmware help. US-8-150W POE
            by gurj1979
            Hi guys.
            I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
            Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
            So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
            Got New chip and writes good.
            THE PROBLEM...
            It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
            Does anyone have a Good Firmware I can have?...
            07-22-2024, 05:13 PM
          • Slapito
            Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
            by Slapito
            I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
            Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
            I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
            I already downloaded the BIOS update file from msi official...
            10-09-2025, 02:00 AM
