Hi folks, I have an issue with my 7 year old Panasonic TX-L50B6B that has appeared within the last few days.
The symptoms are:
Attached is a close-up of the picture in "test mode", to demonstrate the rows of black lines.
A few other observations:
Any pointers much appreciated!
The symptoms are:
- A high pitched "buzzing" / "whining" noise coming from the TV when it is turned on. There is no noise during standby, and the noise persists with all AV connections removed.
- There are noticable horizontal lines in the picture. Upon closer inspection it looks like every few rows of pixels are dead/black.
- Unplugging the TV at the mains for a few hours made no difference
- Adjusting the picture settings (mode, brightness, backlight, etc) made no difference. Backlight appears to be working correctly.
- The noise is most audible on the left hand side of the TV (from the back) which makes me think it is the LD Board (diagram from service manual attached)
- The TV turns on fine and is otherwise fully operational, albeit with a diminished picture. The further you sit away, the less notiable the "lines" are so it is not a huge problem but the high pitched noise is very annoying. It may come and go, but that could be my ears getting used to it!
