I have samsung plasma ps51e550d1r that powers on but doesn't display and the power light blinks 5 times, where to start looking ?
samsung plasma ps51e550d1r no display
Tags: None
Re: samsung plasma ps51e550d1r no display
Photo's of the circuit boards and connections and also voltage readings giving the pin names and voltages on those pinsWilling to help but I'm no expert. -
so we were checking the boards for visible signs of damaged components and shorts and we found a few components in the y board and eventually got all the ones replaced we could see and detect as faulty after 2 or 3 attempts . now the situation is when power is connected the logic board led blinks 5 times in 5 second intervals for 30 seconds and stops and power led starts to do a double blink after 30 sec continuously . we get the 5v standby in the logic board. no vs and va in the y board. when we disconnect the bottom middle cable leading to the logic board the logic board led stays off and the power led 5 times again like original error. what can we check or try next?Comment
we disconnected the y board and tested the vs and va and we got the correct readings . next we check the components on the x buffer board and found three shorted components 2 transistors and a diode we replaced them and connected everything except the y buffer board and it lead to the three components on the x buffer board blowing again.
what could be the fault now?Comment
we used compatible components from spare boards we have.
whats the symptoms of a faulty screen?Comment
what else other then bad replacement components could cause the three components to blow again on the x buffer board?Comment
Assuming...7 Photos -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
by ledbylightHi all!
This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more, and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
11-04-2024, 06:36 PM -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
This specification for the Samsung 9 NT900X5L Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NT900X5L boardview and NT900X5L schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung 9...09-06-2024, 05:33 AM
- Loading...
