Vizio D58U-D3 Black Screen
  • jlf26754
    • Jul 2019
    Hi, I have been looking though the posts, trying to diagnose the fault with my Vizio D58U-D3. When turned on, the screen remains black. Mistake #1- Never connected an antenna to see if there was any audio. There is nothing displayed on the screen using the flashlight test, but the status light illuminates and goes out. Mistake #2 Never noticed the optical audio out port illuminate until after I repaired the set.
    Looking at the power supply board (CAN00), with the TV ON, I never got any voltage on the LED out but the 16 volts to the main board was good.
    Occasionally, the set would start working and I quickly tried to get as many voltage readings as possible. This is further complicated with the two (2) ground references between the high and low voltage sides of the board.
    Rabbit trail #1: VSNS. I could not figure out if this voltage/signal was generated in the power supply or was coming from someplace else.
    Rabbit trail #2: LED power. When the set was working, I had 384V on the lower set of cap's in the high voltage side and when it failed I had 160V (half). The FET's on the underside of the heat sink gave unreliable resistance readings so I decided to replace them. You cannot get the part number (5R380CE-CGJ531) until you pull the entire heat sync. Note: Original FET's are plastic cased, new ones have a metal tab. Be sure and order the bushing and mica insulator kits.
    No luck so next I tried the Opto Isolater (L1539 817B) thinking the VSVS signal was not getting back to the FET ‘s.
    Still no luck so I followed the trace from VSNS down to the Stunt Regulator (AS431 in a TO-92 package).
    After replacing, still no luck.
    My friend who had been watching the whole thing had ordered a LED Driver board, so I replaced it, still nothing.
    Stepping back, I changed my thinking that something else was controlling the VSNS and retraced the interconnections between all boards (sketch attached.)
    In desperation I pulled the Main Bd and went over the board with a microscope and “Et Voila”, there it was. On the CN507, pin 5 was soldered on the bottom of the board but not on the top (where the components live).
    With the set working I finished noting all voltages in the power supply for future BadCap'ers (sketch attached).
    Hope this helps others.
  • grapenuts
    • Jan 2024
    Hi there, I'm having a similar problem, and looking at pin 5 on my main's CN507 I see that it's also not soldered on the top. Did soldering it fix the problem for you? It seems odd b/c, presumably, the tv worked fine before with this unsoldered pin, I'm wondering how that could be the fix? But if it works it may be worth a shot.
    Thank you!
    • MASTER_TECH_101
      • May 2018
      • 12
      Very common issue. You have bad FRC IC, located on Main Board under heatsink. On eBay you will find EEprom that suppose to fix your issue, but it is scam, believe me. Also there is bunch of "repair services" addressing issue, but scam as well. They are garage heat gun tech. They will cook your board to hell and hope it will fix it. Well, only new IC will fix your issue, not stupid reballing or reflowing.
      • mon2
        • 14333
        Is it really an eeprom as in 8 pins or an emmc that is a bga package like we faced with a pseudo bricked Hisense tv? We are studying this fault and about to source some tools for research. Has anyone confirmed if there is a jtag port onboard these main boards?
        • Dustin Kimble
          • Mar 2025
          I just fixed my TV, same model. there were 2 bulged caps that i replaced from some spares i had lying around. Got the TV for free off FB Marketplace and there was no power at the inverter board. this post helped me troubleshoot.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • TheDando
            MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
            by TheDando
            Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
            10-28-2024, 06:59 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • mrtek
            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
            by mrtek
            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
            11-26-2024, 09:58 AM
