Replacing LEDs on LED strip
  • fharris1977
    • May 2017
    • 132
    Does anyone know of a ptc heater that does not burn the LED strip when replacing single LEDs? I'm trying to refurb LED strips and I want my strips to stay as white as possible. On the youtube videos their ptc heaters don't burn the strip at all hardly. Any help or methods would be greatly appreciated.
  • jostewcrew
    • Mar 2020
    • 79
    Re: Replacing LEDs on LED strip
    this is what i use. ive seen others here post ones that are a bit cheaper, but im picky sometimes. this was worth it to me. there is no need to purchase any accessories unless you plan to start in on phone boards.
    https://www.unionrepair.com/mechanic...0-a11-a12.html
    • chrismurphy
      • May 2014
      • 251
      • australia
      Use a standard iron upside down ,works great
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4289
        • Italy - Milan
        use a standard iron upside down ,works great
        eh??
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Originally posted by Davi.p
          eh??
          I think this is what is meant.
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • VitalComputing
            Replacing Mode Indicator LEDs
            by VitalComputing
            I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
            I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
            I thought I could just put a resistor...
            09-17-2023, 04:43 PM
          • edugimeno
            About replacing individual LEDS on BL strips
            by edugimeno
            Hi There!
            Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
            At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
            How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
            11-07-2022, 11:12 AM
          • tmhobadcap
            TCL 65S403 Backlight LED Question
            by tmhobadcap
            I got the TV from a friend. He claims that no image but sound from the TV.
            I confirmed that when shine a flashlight on to the screen, I can see the image. And this should be backlight problem.
            I open up the TV and found a few leds failed. And now I am ordering a new set of backlight strips for it.
            But there is something that I do not understand when checking the leds. I do not have an led tester. I only use a bench power supply. I first set the voltage to 3V and current to 10mA. I could not light up the led until I increase the voltage to 12V. I understand most...
            05-25-2025, 11:03 AM
          • edugimeno
            Help findinf LED strips for TDSystems K32DLT1H
            by edugimeno
            Hi There!
            I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
            Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
            Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
            11-05-2022, 03:36 PM
