Samsung UA46C8000 Vertical lines
  • RooTV
    • Apr 2020
    • 128
    Hi there.
    I have a samsung UA46C8000 that has a screen full of coloured vertcal lines and nothing else.
    I pulled it apart for a cursory look and to unplug all connectors and reconnect them etc. No bad caps or burnt parts on boards
    I did however find a black line along one of the cables going to the TCon board from the panel?
    It looked like it was burnt out and also has left a black line on the connector.
    Im not sure what this is or if it is the issue? but suspect it may be.
    If it is, the cable comes from the panel so I suspect it is not fixable? Hoping it is just the cable and not the TCon board, but not sure how to find out.
    After checking all cables I put the tv back together and turned it on hoping for a miracle, but now instead of masses of coloured lines, there is just nothing. The backlight comes on but I cant get a picture or a menu or anything.
    Not sure where to go now.
    I have attached photos to make it easier for your comments.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UA46C8000 Vertical lines
    It looks as though excess current has burnt the ribbon cable either as a result of a fault on the panel strip connector or the Tcon itself.
    I think the prognosis is not very good but I hope I'm wrong.
    Is it possible to disconnect the cable between the Tcon and panel strip?
    • RooTV
      • Apr 2020
      • 128
      I was just thinking about that. If I can disconnect it from the panel end I would just have to get another cable.
      Where I would get one from is another issue. Are they model dependent or are they just a cable?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        That would only be a partial solution. Even if you can the next thing to find out is why the ribbon cable burned and try and identify where the fault lies. If it's the Tcon then that is replaceable. If it's the panel strip then that's a bigger problem.
        • R_J
          • 9557
          I would bet money someone cleaned the screen and liquid ran down and damaged the board that connects the lcd itself, Remove the front bezel and inspect that board, but it is likley not repairable
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I would agree with RJ. Remove the bezel and inspect the panel strip. Handle the panel strip with care since it is bonded to the panel and can be damaged.
            • RooTV
              • Apr 2020
              • 128
              would liquid damage be obvious?
              Is there any particular part to check?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Generally it is noticeable. Check along the full length of the panel strip.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4367
                  • Italy - Milan
                  HI, i have fixed a ue40s800 that is much very similar to yours, there was a shorted mlcc capacitor on the bottom side of the tcon, in the power section, my flat cable luckily was perfect but the p.supply track to the tcon on the mainboard, on the bottom side, was burned but almost easy to fix. The capacitor was near perfect cosmetically.
                  • RooTV
                    • Apr 2020
                    • 128
                    Davi.P
                    You say yours was similar to mine?
                    the connector from the tcon board to the panel, can you unconnect it from the panel to replace it?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4367
                      • Italy - Milan
                      Sorry, i forgot to download the first two photos, in fact the damage is on the panel, you have to find it and after replace the broken track with wire..
                      • Falki
                        Colorful LCD Vertical Lines on Samsung ue55es8090
                        by Falki
                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                        A similar issue has been posted as well but also with no actual response ...
                        08-12-2025, 04:19 AM
                      • polaro
                        Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                        by polaro
                        Greetings,
                        I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                        08-27-2022, 08:46 AM
                      • Stanley1843
                        by Stanley1843
                        06-29-2024, 11:54 AM
                        09-07-2024, 05:50 AM
                      • Anonmis
                        Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                        by Anonmis
                        Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                        The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                        12-01-2023, 04:31 PM
