Vizio E70-E3 will not power up
  • busaboy
    • Dec 2015
    • 17
    • usa
    Re: Vizio E70-E3 will not power up
    From page 49 of the manual the regulators output is 3.39volts. Unfortunately the text is very distorted so I cannot tell how many parts are fed by 3.39volts. 3.39volts feeds a FET switch and yields 3.3volts. I'm going to pull the board, remove L201, back-feed 3 volts and see if I can get a cap to heat up or pop. Since it's not my TV and my buddy is unwilling to spend $100 for a used replacement, I'm gonna get medieval on the board.
    • R_J
      • 9551
      I believe the voltage from U201 is 3.3v, V_3.3SB If that is the case it then feeds Q201 (switch) (page50) which is then called V_3.3M. It also feeds D632 (page 52)
      So it would seem V_3.3SB is only for standby circuits and if there is no short after Q201 there are not too many components that are connected to that line.
      If you have a bench supply that can supply 1~2 volts (or use a 1.5v battery) connect - to ground then momentarily ( a second at a time), touch the + to the V_3.3SB line, and feel around for a hot spot. some people spray an area of the board with alcohol which will evaporate very fast near the shorted component.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Use your meter set to ohms, set powered off and measure the resistance to ground at the following test points.
        TP215 & TP219 (If I read them correctly since quite blurred)
        • busaboy
          • Dec 2015
          • 17
          • usa
          I found V_3.3SB also feeds the IC on page 60. Going to pull L201 and apply DC.
          Do you have a better copy of the manual?
          • busaboy
            • Dec 2015
            • 17
            • usa
            I measure a "short" with a DVM at the switcher output capacitors. I'm guessing this is one of the TPs you mention. The text is so distorted every TP seems to be "TP215" :-(.
            PS
            I have an extensive electronics lab at my house. I can pretty much test anything. Attached is a few shots. Two guys from GE testing a digital radio for a locomotive...
            • busaboy
              • Dec 2015
              • 17
              • usa
              #26
              I injected DC into the "output" of L201 because it looked like too much of a PITA to remove. I started with one power supply, then a bigger one and then a much bigger one (300watt). I injected 1 volts and then upped it to 2 volts. The circuit drew 6 amps with the PS on current limit. It took a lot of feeling with my hands but the problem seems to be a short inside the FOXCONN WiFi module. I will pull the shield off and see if I can fix it. Probably a bad cap in the module.
              • R_J
                • 9551
                This is the only manual I have and I don't know why it is blurry, (some Panasonic plasma tv manuals are also like this) I did mention the module earlier as a problem, There is information on the module such as pinout.
                • busaboy
                  • Dec 2015
                  • 17
                  • usa
                  #28
                  I traced the problem to the WiFi module due to the heat it was giving off from forcing current into the shorted MLCC cap(s). It must have gotten pretty hot inside the shield.
                  I replaced the 2 MLCC caps in the WiFi module and 2 MLCC on the output of L201 with cheap two 10uF axial aluminum electrolytic caps. The 2 MLCC caps on the output of L201 were OK but I didn't want to reuse them. Desoldering the shield off the WiFi module took a lot of heat from a 80 watt soldering iron. I didn't reattach it.
                  I cannot say which of the 2 MLCC caps in the WiFI module were shorted. I toasted the area pretty good with 2 volts at 6 amps as shown in the pic. The second pic shows the 2 caps. Lucky the vias and traces could handle the current. The TV seems to be working though I didn't check if WiFi is OK. Not my problem anymore....
                  • busaboy
                    • Dec 2015
                    • 17
                    • usa
                    #29
                    Thanks. Unfortunately with the shield soldered on the WiFi module and the way the module was attached to the main PCB, it was difficult to locate the short.
                    I did find differences on my PCB. Q201 is a BJT versus a MOSFET in the schematics. I couldn't find Q202.
                    I wish I still had a special tester I made for finding shorts. It used a 10MHz oscillator feeding a 50 Ohm power buffer that fed a BNC connector. The BNC also fed a NE604 FM demodulator IC. I used the NE604 RSSI output (log amplifier), to drive a meter. With nothing connected the meter read maximum. As the impedance got lower, the meter reading dropped. It could find which connector was shorted on even a very short cable. It could find a short along a trace on a PCB. At 10MHz an aluminum electrolytic cap will have a higher impedance than a short. It would have found a shorted MLCC if I could get the probe close enough.
                    • R_J
                      • 9551
                      Thanks for the follow up, I suspect the mlcc are just for some filtering and the wifi likely still works.
                      • zzlink
                        • Jan 2023
                        • mexico
                        #31
                        Ayuda necesito el manual de esta Tv vizio e70-e3, por favor, donde lo puedo descargar?
                        • zzlink
                          • Jan 2023
                          • mexico
                          #32
                          • FrancescoV
                            Onkyo HT-R390 no sound output, video output ok
                            by FrancescoV
                            Good morning everyone,
                            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                            The firmware reported is the following:
                            M:1.00/11107BLP
                            D:?.??/????????
                            O:1.00/11107AL
                            The DSP firmware given the question marks seems corrupt.
                            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                            05-11-2025, 02:59 AM
                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                            by sam_sam_sam
                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                            I bought this from an eBay seller but unfortunately they only had one
                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                            I bought three of from them to also make battery packs with this output power limit in mind
                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                            04-23-2025, 05:50 AM
                            Corsair CX750M [Model 75-002019] - burned output toroid inductor
                            by momaka
                            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                            09-19-2021, 08:44 PM
                          • CoppellTVRepair
                            Troubleshooting PFC with SPC1012T not raising output
                            by CoppellTVRepair
                            It has been a long while since I posted here to ask anything....hope you can help.
                            I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                            I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                            03-09-2025, 10:38 PM
