Samsung UN65EH6000F power supply IC801
  • bkeith
    • May 2011
    • 8
    I picked up a Samsung UN65EH6000F locally because the seller said it "just died" one day.
    Power supply board is PSLF131C04E aka BN44-00560A.
    On visual inspection, it appears that ICM801 is blown out. Most of the surface is cratered out so I can't even read a part number.
    Another post about this same model refers to it as the SMPS driver. That makes sense as there is no power activity.
    I'd like to find a schematic or at least identify the part number and order a replacement if possible.
    Thank for any assistance.
  • R_J
    • 9515
    Re: Samsung UN65EH6000F power supply IC801
    It believe it is a FSFR1700XSL. I would also check the diodes DM851 ~ DM854, on the secondary of TM801s, and check the solder connections on TM801s
    • bkeith
      • May 2011
      • 8
      Thanks. It looks pretty similar, but the installed IC has 9 legs and the datasheet for the FSFR line shows 10 legs with one missing.
      And I scraped of the silastic and the last two letters of the part number are "AC".
      I'll pull the board and start following traces to see if it is compatible.
      I've found schematics for other BN44 power supply boards, but not this exact one, BN44-00560A.
      If anyone else has links or notes, please speak up.
      • R_J
        • 9515
        The two letters "AC" are likely the top line which is part of the date code
        • bkeith
          • May 2011
          • 8
          On closer look, yup, you nailed it.
          Looking at the datasheet https://cdn.badcaps-static.com/pdfs/...1be5f4a446.pdf
          Is there any disadvantage in using the higher rated 2100 part over the 1700 part?
          They are pennies difference from mouser/digikey.
          • R_J
            • 9515
            most of the specs are the same, the only difference I see is the RdsON resistance is a lot lower which might be an issue (1700= 1.25Ω) (2100= 0.51Ω)
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • cheeky2
              Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
              by cheeky2
              This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
              I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
              Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
              06-15-2025, 05:12 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
