Samsung PN50A450 - Vertical Bars
  • csquaredin
    • May 2020
    • 3
    There is a 2-3" vertical black bar on the left side of the screen running from top to bottom. There are also two vertical yellow lines, one next to the black bar and one inside. (See attached picture.)
    After browsing through the forum, it seems like most say it is likely a bad panel. Is this the case here? Are there any steps I can do to troubleshoot before hauling it away? I'm willing to try a board replacement if there's a chance that would fix it. If there's no hope, my wife will be happy that I'm finally hauling it away.
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Samsung PN50A450 - Vertical Bars
    Almost certainly a bad panel from the looks of it.
    • csquaredin
      • May 2020
      • 3
      Are the logic buffer E & F boards along the bottom of the TV replaceable? Or are they soldered to the panel?
      • rccrasher65
        • Mar 2014
        • 626
        Panel shit the bed, sorry!
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
          09-07-2024, 05:50 AM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • kotel studios
          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
          by kotel studios
          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
          08-06-2025, 02:07 AM
        • JesusJones
          Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
          by JesusJones
          Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
          The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
          04-13-2021, 01:45 PM
