phillips 32inch led back light voltage drops
  • elpiko
    • May 2020
    • 25
    • Seychelles
    hi all i have 32 inch phillips tv that turns on show logo then blank screen. so i took it apart, it has a total of 12 leds on two strips of 6 on a strip.
    ive tested both strips with 24v and all of them lights up but was flickering in dont know if that was due to my power supply i tested it with not making good connection but all led lights up.
    now when you turn on the leds flashes bright briefly then off, testing the voltage it spike up to 40v then drop to 13v and stay there. i tried testing the board without the leds connected i still get the spike of 40v then drop to 13v .
    ive check caps they all look ok. any idea?
    Re: phillips 32inch led back light voltage drops
    1) The output will Voltage will spike up if it sees no load, then the protection circuit kicks in and shutdown the boost converter circuit so the Voltage you see is the feeding Voltage (13V) to the boost converter.
    2) Did you test the whole LED string will require more than 24V with current limiter by connecting the power source to the LED connector (LED connector not connected to the board) that goes to the power supply board.
    3) LED should not be flickering when tested.
    4) Do you still have the pictures of the LED strips and how they are linked together?
    5) How many wires are there on the LED connector?
    • elpiko
      • May 2020
      • 25
      • Seychelles
      i tested one led strip which has 6 led on it with a laptop charge of 24 volt. it was lighting quite dim and fliker dont know if it was due to lose connection .
      the two strips are totally separate from each other. each have two wires then goes in one connector where its connected on power supply.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Dim and flickering sounds like a faulty led(s) on the strip.
        How many leds were you attempting to test with the 24V supply?
        24V on 6 leds is likely to fry the leds if they are 3V leds.
        • elpiko
          • May 2020
          • 25
          • Seychelles
          i tried to test a strip with 19 volt at first it did not light up so i tired 24v and it light up but dim. if i connect the power supply and connect both strip and power on all the leds light up for few seconds and then turn off.since the voltage i boosting up to 40v and i have 12 led in total that makes each led 3.3v i guess so the 19v should have light up a strip fine but didn't
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Take a video of the leds as you power them up. Check it frame by frame and you will find that some leds are not working.
            • Repair_dane
              • May 2020
              • 42
              • Danmark
              Adjust the brightness on the video when recording, so you can see every single LED clearly. LEDS are very bright for human eyes and can be tricky to spot when faulty
                "the two strips are totally separate from each other. each have two wires then goes in one connector where its connected on power supply." Are you saying that the two LED strips are connected in parallel?
                The LED power supply is rated at 40V as shown on the print on the circuit board.
                If the LED strips are connected in series then the Vf at high current will be 12 LEDs x 3V = 36V.
                If LED strips are connected in parallel then then the LED will be 6V LEDs.6 LEDs x 6V = 36V.
                • elpiko
                  • May 2020
                  • 25
                  • Seychelles
                  so you think the problem is with the leds rather than the power supply? i will try to the the tv apart again to record the leds.
                  • elpiko
                    • May 2020
                    • 25
                    • Seychelles
                    hi so i took the tv apart again but just to note that even if the back light is not working if i use a flash light i can see image on the screen. so i use an led bulb circuit to make an led tester. one of the strips works fine but the other one does not light up.
                    so i took the small cover off an notice one of the led is burned. since i had no spares led from an old tv i used one of the led from the bulb ive took the circuit from as replacement.
                    when i test the strip now all led light up but the replacement is a bit dimer than the original but still light up. now putting back the tv together i thought all would be fine since all the led are lighting up with my tester. but i get same problem all led flashes show logo the led goes off when i power on the tv.
                    could it be the replacement led ive used lower voltage than the other so its detecting a fault or something?
                    what if i bypass the tv circuit that powers the led and i use a separate one like the test ive made to power the led then my tv will work again would there be a downside to this?
                    • elpiko
                      • May 2020
                      • 25
                      • Seychelles
                        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                        by sam_sam_sam
                        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                        I am comparing them to a brand new one that I installed
                        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                        I going to let it run for several days before I remount back on the wall next to the...
                        09-05-2024, 06:48 PM
                      • PNI E.
                        tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                        by PNI E.
                        hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                        02-20-2025, 08:36 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • koby058
                        vostro comes up with back light but no picture
                        by koby058
                        Hi people!!
                        The owner said it showed bad picture once in a while (attached)
                        I see that there is back light but no picture.
                        I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                        Also attached schematic and BDV
                        LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                        07-13-2025, 01:03 PM
                      • jdawg99
                        LG 47LA620V Same LED Failing Back Light Issues
                        by jdawg99
                        Hi All,
                        I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
                        04-23-2023, 01:04 PM
