Hisense H55A6500UK backlight, sound but no display
  • notallbad
    • Oct 2012
    • 1190
    Tv turns on, backlights on but no picture, sound is present. Responds to remote, mute, voll up/down etc..
    On initial power up the red led comes on solid, then switch on red led blinks 17 times. After initial power on from stby to on theres just 4 red blinks. (just for info really).
    PS: RSAG7.820.7748/ROH
    Main : RSAG7.820.7970/ROH
    T-con : RSAG7.820.7932/ROH
    Panel : HD550S3U51-TA
    PSU voltages:
    XP701
    Stby-----On
    110------125.7
    0----------0
    110------125.7
    0----------0
    XP805
    ---------Stby---------On
    gnd------0----------0
    ana------0----------0
    vamp---18.4-----18.6
    stb-------0.05-----2.69
    12v------9----------12
    sw-------0.03------4.69
    bri-------0.03------1.53
    gnd-----0-----------0
    nc-------0-----------0
    12v-----9-----------12
    gnd-----0------------0
    So, apart from the ana pin I guess these all look good?
    Theres no obvious damage on either side of any of the boards and appear to be getting various voltages that look good around the main board and getting 12v, 1.2v & 1.8v on the T-con.
    Theres a very, very faint 4 inch wide vertical bar around the middle of the screen which lines up with one of the tabs so its possible even if the tv can be fixed there will be bigger issues ahead, tab bond fault!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Hisense H55A6500UK backlight, sound but no display
    Are you saying the 12V supply is currently 9.12V
    • notallbad
      • Oct 2012
      • 1190
      Sorry. the spacing has come out wrong in the post.
      Edited post to separate them out.
      The 12v lines are 9v in stby and 12v when powered on.
      • Diah
        • Feb 2013
        • 6425
        try to downgrade the firmware before you go on yours thought.
        and check before all if you have VCC 12V on the T-CON
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I notice the board says 12V @ 3A, 16V @1.5A and 160V @ 450mA
          Do you have the 16V and 160V supplies?
          Edit
          Just noticed that it looks like the 16V is the 18V supply
          • notallbad
            • Oct 2012
            • 1190
            Theres 18v on VAmp on XP805 connector and 125v for the backlights on connector XP701.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              The backlight voltage appears low as per what's written on the psu.
              Can you clearly see the backlights are up nice and bright from the back of the panel?
              I have seen that you say the backlights and sound working but no picture.
              • notallbad
                • Oct 2012
                • 1190
                Yh, the backlights are definately on and bright.
                Disconnecting the T-con ribbons to the panel boards one at a time makes no difference, still no picture/menu.
                  • 12235
                  • U.S.
                  See if there's voltage on each side of tcon fuse, pos. probe on each side, neg. probe on chassis ground.
                  • notallbad
                    • Oct 2012
                    • 1190
                    Yh 12v on both sides of fuse and 1.8v on vcc1.8 and 1.2v on FRC_1.2V1.
                    Appears to be a short across VD8 - MR340, even with one side lifted the short exists between the pads, not the diode.
                    Short across caps C238, C239, C177 and C176.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Is the MR340 the correct number?
                      https://tinyurl.com/y788q8ep and it appears to be a mosfet
                      Where is it on the tcon? top or bottom?
                        • 12235
                        • U.S.
                        Are those shorts there with nothing connected to tcon?
                        • notallbad
                          • Oct 2012
                          • 1190
                          M8R340 or MBR340, top right. DMM on diode setting get a reading of 120 one way only.
                          On the pcb pads get a short.
                          Sorry, picture upside down.
                          T-con disconnected from main and panel.
                            • 12235
                            • U.S.
                            That looks like a match, not sure on the postage, it just gave the rates to the U.S. when I clicked it: https://www.ebay.co.uk/itm/LVDS-TCON...EAAOSwgZ5cXu1e
                            • notallbad
                              • Oct 2012
                              • 1190
                              Yh, I think buying a replacement T-con might be the best way to go!
                              • neilc6
                                • Nov 2015
                                • 1550
                                Power up the tv with the tcon to panel ribbons connected one side at a time to confirm you dont have a panel fault.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  yh done that, no difference!
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    It is possible that one of these caps are responsible for the short circuit.
                                      • 12235
                                      • U.S.
                                      Originally posted by dick_barton
                                      it is possible that one of these caps are responsible for the short circuit.
                                      +10
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        So, it would seem C177 was shorted.
                                        Removed C177 and the cap is shorted.
                                        The short across the other caps and the M8R340 has gone.
                                        Also on the reverse side, VD5 showed as a short, but also now gone.
                                        But what to replace it with? Its tied to the 12v rail. 0.1uf???
                                        Dare I try it without this cap attached?
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                        • jake12021
                                          Hisense 65p7 sound but no picture
                                          by jake12021
                                          I have got a Hisense 65p7 tv. The red standby light is solid when plugged in. When turned on with remote the red standby light flashes 17 times and then stays off. The screen lights up the smallest amount and need to turn off with remote again to get back to a solid standby light. Ive already gone through replacing power board and main board and neither fixed the issue. The back lights under the back panel are lit up when tv is on and sound still works. Wondering if I should try to replace the t-con board? Or is there any tests for the leds? (I have a voltmeter)...
                                          02-19-2023, 08:43 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
