Hisense 65p7 sound but no picture
  • jake12021
    • Feb 2023
    I have got a Hisense 65p7 tv. The red standby light is solid when plugged in. When turned on with remote the red standby light flashes 17 times and then stays off. The screen lights up the smallest amount and need to turn off with remote again to get back to a solid standby light. Ive already gone through replacing power board and main board and neither fixed the issue. The back lights under the back panel are lit up when tv is on and sound still works. Wondering if I should try to replace the t-con board? Or is there any tests for the leds? (I have a voltmeter)
    • 12229
    • U.S.
    Re: Hisense 65p7 sound but no picture
    can you post some clear straight on pictures of each board and one of the whole back, as to see how everything is connected.
    • Storyteller12
      • Jun 2020
      • 625
      Usually if you have sound and backlights power on the mainboard and power supply are good.
      Try unplugging one side at a time of the lvds cables going from the panel to the tcon and turning on. See if you get a picture on half the tv.
      • Hisense65P7
        • Mar 2023
        • 12
        Hi Jake,
        I have the exact same issue with my Hisense, down to the red light flashing 17 times and no picture.
        Just wondering if you have found a solution?
        I was going to go ahead an order the LED light strips to see if this is the issue.
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • JohnML1975
          Samsung UA50TU8000W no picture and no sound
          by JohnML1975
          Hello All
          have seen posts on this model in here but my problem sounded different so thought i would create a thread
          TV will not turn on
          There is no standby light
          When I press ON button for remote the red standby light does flash but no picture and no sound
          From the back of the TV I can see the red light on the back of the mother board
          Holding torch to the screen I cannot see a picture
          I removed the back cover
          Observing the boards I cannot see any damage
          I disconnected the main board from the power supply
          the back...
          08-30-2025, 09:40 PM
        • slimsoul
          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
          by slimsoul
          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
          03-12-2024, 03:55 AM
        • koby058
          vostro comes up with back light but no picture
          by koby058
          Hi people!!
          The owner said it showed bad picture once in a while (attached)
          I see that there is back light but no picture.
          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
          Also attached schematic and BDV
          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
          07-13-2025, 01:03 PM
