Sharp LC-70LE745U no backligth no image
  • hmendez86
    • Jun 2015
    • 344
    • united states
    I got this led sharp 70' inch.....i turn on the tv and i did get the geen ligth pulse on the main board and itblinks and 12v on t-con....on the power supply side am getting 83.4v for leds output....i was thinking that regulator on the power supply but neither too is working fine getting 13.2v
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: Sharp LC-70LE745U no backligth no image
    [/attach]
      • 12145
      • U.S.
      Try test #3 below, try to do it just as instructed with the pins numbered and labeled.
      • hmendez86
        • Jun 2015
        • 344
        • united states
        I change the power supply.....change power supply cables to main board....and still nothin.....i removed the bar leds and they all work well with my led tester...
        • hmendez86
          • Jun 2015
          • 344
          • united states
          Any more suggestions
            Read post #3 again and follow the request.
            • hmendez86
              • Jun 2015
              • 344
              • united states
              1.pnl-12v
              3.gnd-0.0
              5.ur-13.2v
              7.ur-13.2v
              9.gnd-0.0
              11.gnd-0.0
              13.ac-det-3.3v
              15.bus-5v
              17.pwm1-0.0v
              19.dimmer-0.0v
              21.ofl-0.0v
              23.pwm2-0.0v
              2.pnl-12v
              4.gnd-0.0
              6.ur-13.2v
              8.ur-13.2v
              10.gnd.-0.0v
              12.gnd-0.0v
              14.ps_on-3.0v
              16pnl-pow-3.3v
              18.nc-33v
              20.nc-3.3v
              22.error-0.0
              24.stb-3.3
              • hmendez86
                • Jun 2015
                • 344
                • united states
                I already add another set of leds and still not turning on
                  • 12145
                  • U.S.
                  "18.nc-33v
                  20.nc-3.3v" Something wrong there, nc stands for not connected, so check if they are connected.
                  • budwich
                    • Jul 2015
                    • 3097
                    try the force on sequence?
                    • hmendez86
                      • Jun 2015
                      • 344
                      • united states
                      Yea i know something is wrong at NC should be not connection and am reading 3.3v on #18, #20 both 3.3v
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        How do mean to force the sequence ....i try the vol- and chan+ to force
                        • budwich
                          • Jul 2015
                          • 3097
                          that's "better" than what you wrote previously... 33v on pin 18 :-)
                          perhaps the NC means that there is no circuit connected at the other end. Check where those go at the other end.... likely no where.
                          the force on sequence involves holding down some buttons as you indicate but also plugging in power at the same time.
                          You are sure that you are not getting any flash sequence on the front panel?
                          • hmendez86
                            • Jun 2015
                            • 344
                            • united states
                            The first sequence was one slow one fast means to led problem...but i did force to those buttons and work but no led goes on only main pulse green ligth and t con 12v.
                              • 12145
                              • U.S.
                              17.pwm1-0.0v
                              19.dimmer-0.0v
                              21.ofl-0.0v
                              23.pwm2-0.0v Looks like problem there if those are with power on, if ofl is same as bl-on then it looks like the mainboard isn't sending the on signal??
                              • hmendez86
                                • Jun 2015
                                • 344
                                • united states
                                On pin 21-ofl am now getting 3.0v
                                  • 12145
                                  • U.S.
                                  Looks better, what about the other 3?
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    sorry, but not quite understanding.
                                    are you getting a "flashing code" from the front panel without doing any "force on"..... OR that was the flash code before you replaced the leds?
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      No, when i replce the main board for the first time i was getting one slow and one fast..so i did the force button and then the blinking ligth was gone and the main start to function because the green ligth on main started to pulse and t con had 12v on connector. So when all started to work there was no back ligth so i was thinking it was led, i did buy the whole set of led and is doing the same thing so now i am ????
                                      • hmendez86
                                        • Jun 2015
                                        • 344
                                        • united states
                                        The other 3 pins 17,19,23 they are at 0.0v
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
