I got this led sharp 70' inch.....i turn on the tv and i did get the geen ligth pulse on the main board and itblinks and 12v on t-con....on the power supply side am getting 83.4v for leds output....i was thinking that regulator on the power supply but neither too is working fine getting 13.2v
Sharp LC-70LE745U no backligth no image
Re: Sharp LC-70LE745U no backligth no image
Try test #3 below, try to do it just as instructed with the pins numbered and labeled.Comment
Read post #3 again and follow the request.Never stop learning
1.pnl-12v
3.gnd-0.0
5.ur-13.2v
7.ur-13.2v
9.gnd-0.0
11.gnd-0.0
13.ac-det-3.3v
15.bus-5v
17.pwm1-0.0v
19.dimmer-0.0v
21.ofl-0.0v
23.pwm2-0.0v
2.pnl-12v
4.gnd-0.0
6.ur-13.2v
8.ur-13.2v
10.gnd.-0.0v
12.gnd-0.0v
14.ps_on-3.0v
16pnl-pow-3.3v
18.nc-33v
20.nc-3.3v
22.error-0.0
24.stb-3.3Comment
"18.nc-33v
20.nc-3.3v" Something wrong there, nc stands for not connected, so check if they are connected.Comment
perhaps the NC means that there is no circuit connected at the other end. Check where those go at the other end.... likely no where.
the force on sequence involves holding down some buttons as you indicate but also plugging in power at the same time.
You are sure that you are not getting any flash sequence on the front panel?Last edited by budwich; 05-03-2020, 09:21 AM.Comment
17.pwm1-0.0v
19.dimmer-0.0v
21.ofl-0.0v
23.pwm2-0.0v Looks like problem there if those are with power on, if ofl is same as bl-on then it looks like the mainboard isn't sending the on signal??Comment
are you getting a "flashing code" from the front panel without doing any "force on"..... OR that was the flash code before you replaced the leds?Comment
No, when i replce the main board for the first time i was getting one slow and one fast..so i did the force button and then the blinking ligth was gone and the main start to function because the green ligth on main started to pulse and t con had 12v on connector. So when all started to work there was no back ligth so i was thinking it was led, i did buy the whole set of led and is doing the same thing so now i am ????Comment
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 10:56 AM
This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-06-2024, 10:56 AM
This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 10:56 AM
This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-06-2024, 10:56 AM
- Loading...
