LG 47LB6500.ATR - No Picture/No Back light but has standby voltage
  • mugunthans
    • Dec 2016
    • 32
    My living room TV kaput after lighting storm along with Cable Set-top Box connected via HDMI-3.
    So, with my little knowledge of electronics I thought of fix it by myself.
    First, I searched forum for any case registered existing if anyone have same issue/symptom.
    Found some few case near matching But not really the same !!!
    Now decided to open a new thread.
    Brand: LG
    Model: 47LB6500.ATR
    Panel: LC470DUH (FG)(P2)
    Main Board: EAX65363904
    Problem:
    No Back light
    No Picture
    No Standby light (Red LED)
    Sign of dead !!!
    Observation:
    HDMI-3: D3214/D3215 - Burnt - close look with Magnification glass
    Power Supply Reading as below
    Input Power Supply - 240v
    Connector P201
    PWR-ON - 3.5v Ok
    3.5v - Ok
    12v - Ok
    24v - Ok
    P-DIM1&2 - 0v
    DRV-ON- 0v
    P801
    LED strip: LED OFF - (Supplied 3.5V with 10K Resister to DRV-ON || All LED Turned ON)
    C610
    Power Capacitor : 358v
    Main Board Voltages
    Enable voltage is 0.8v
    All below IC input voltages are Ok but output 0v which is responsible to generate 3.3v,5v,1.5v,1.1v
    IC2300
    IC2334 (Typo in Schematic IC2304)
    IC2303
    IC2301
    Since there was no output of 3.3v,5v,1.5v,1.1v from above ICs, IC2303 has no output of 2.5v
    IC3000 input Vdd 3.5v is good
    But from IC3000 - enable pin feeding to above ICs were absent (0.8v) and also this IC is heating above normal.
    Any help would be much appreciated...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 47LB6500.ATR - No Picture/No Back light but has standby voltage
    IC2300
    IC2303
    IC2301
    Looks like IC3000 is not providing the Power_On/Off_1,2,3,4 to enable those voltage regulators.
    • mugunthans
      • Dec 2016
      • 32
      I'm thinking the same but would like to hear some experts guidance.
      • diif
        • Feb 2014
        • 6978
        • England
        If the protection diodes are burnt, I would think the processor is dead.
        • mugunthans
          • Dec 2016
          • 32
          May be!!! but since IC3000 dead, can come to a conclusion after the replacement. Also there are chances that the HDMI diode burnt to protect Processor.
          Fingers cross until replace MICOM IC...
          • mugunthans
            • Dec 2016
            • 32
            Is there any pre-programming required in Micro Controller Chip before fix into board or it is Plug n Play ?
            IC3000 - Renesys R5F100GEAFB
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I would imagine that since this is a microcontroller with 64K flash memory, 4K Flash Data and 4K Ram it would need to be programmed.
              • mugunthans
                • Dec 2016
                • 32
                Any body has a source code ?
                • PNI E.
                  tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                  by PNI E.
                  hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                  02-20-2025, 08:36 AM
                • koby058
                  vostro comes up with back light but no picture
                  by koby058
                  Hi people!!
                  The owner said it showed bad picture once in a while (attached)
                  I see that there is back light but no picture.
                  I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                  Also attached schematic and BDV
                  LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                  07-13-2025, 01:03 PM
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  by sam_sam_sam
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                • slimsoul
                  Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                  by slimsoul
                  Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                  I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                  I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                  The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                  03-12-2024, 03:55 AM
                • JohnML1975
                  Samsung UA50TU8000W no picture and no sound
                  by JohnML1975
                  Hello All
                  have seen posts on this model in here but my problem sounded different so thought i would create a thread
                  TV will not turn on
                  There is no standby light
                  When I press ON button for remote the red standby light does flash but no picture and no sound
                  From the back of the TV I can see the red light on the back of the mother board
                  Holding torch to the screen I cannot see a picture
                  I removed the back cover
                  Observing the boards I cannot see any damage
                  I disconnected the main board from the power supply
                  the back...
                  08-30-2025, 09:40 PM
