Hitachi LE55U516 - Vertical lines - Not always present
  • jason123
    • Oct 2015
    • 1083
    *** Board Photos here : https://www.badcaps.net/forum/showth...light=LE55U516 ****
    TV Works fine, but there are thin vertical lines (not necessarily all the way from top to bottom - sometimes top to 1/3 or 2/3 of the screen) and these are not always there. They seem to come and go depending on the type of picture, colors,...
    There is no firmware update for this model per the manufacturere.
    I did a full factory reset.
    When I got it, it had bad backlight (a couple of bad LEDs) - fixed these only to find the vertical lines. I Reseated ribbon cables, and no change.
    I always thougth vertical lines are panel issues. Any thoughts?
  • nomoresonys
    • 12216
    • U.S.
    Re: Hitachi LE55U516 - Vertical lines - Not always present
    I had a tv not long ago that when I tightened up the frame around the panel it had to be just right, too tight or loose and would have thin red lines was tedious but got it right after some adjusting.
    • jason123
      • Oct 2015
      • 1083
      So this is a bit different I think.. flexing or moving the TV really has no effect. With or without cover, doesn't matter either.
      • jason123
        • Oct 2015
        • 1083
        Could this be a Tcon or Main board issue??
        • nomoresonys
          • 12216
          • U.S.
          Maybe clean the ribbon cables and check for good clean connection of lvds from tcon to mainboad, sometimes just unplugging and re-plugging clears things up.
          • nomoresonys
            • 12216
            • U.S.
            Try powering up one side of the screen at a time by disconnecting each ribbon cable, one at a time and see what you get on display.(always disconnect and reconnect cables with power cord unplugged to avoid any damage)
            • jason123
              • Oct 2015
              • 1083
              thanks.. No luck.. I still get these vertical pixels (can't really call them lines because they don't extend from top to bottom) now and then..
              • nomoresonys
                • 12216
                • U.S.
                Make sure the connectors are aligned right, could be a bad lvds or tcon ribbon cable, maybe check the MLCC caps on the driver board for very low ohms. Could be a mainboard issue, weak/bad cap or something. The"tape cutoff" method might work.
                • Stanley1843
                  Screen Display Vertical Multicolor Lines
                  by Stanley1843
                  Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                  06-29-2024, 11:54 AM
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  Sadly it has vertical lines at the left and one line in the middle-right.
                  I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                  I have factory resetted the TV as well but also with no luck.
                  I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • visionbluedemon
                  Help. Sony kd-65x85dj vertical lines
                  by visionbluedemon
                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                  tried blocking LC lines too, but same results
                  is it lcd panel issue or tcon board issue?...
                  07-25-2025, 04:56 AM
                • gpo23
                  Sony KDL-40V3000 - Vertical lines
                  by gpo23
                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                  With the new t-con the color are good but there are vertical lines on all the screen :
                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                  Is there a way to fix the vertical lines on the new t-con ?
                  Thank you for your help
                  gpo23...
                  10-04-2023, 09:11 AM
                • hendue
                  BenQ 2765HT vertical lines, no picture
                  by hendue
                  I was trying to fix the monitor, which was giving me the following pictures:
                  It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
                  I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
                  Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
                  I turned around...
                  09-09-2025, 08:27 AM
