715g6338+psu.
Re: 715g6338+psu.
I probably need to get some parts... What do you reckon I might need to test and stuff say 5 ten steps down... If it takes so long... I can get them all first...
Thanks!Comment
Re: 715g6338+psu.
You just need a few 1K ohm resistors to carry out most tests.Willing to help but I'm no expert.Comment
Re: 715g6338+psu.
You are correct. I was looking at two psu schematics at the time and posted the wrong one.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by dick_barton; 04-06-2020, 08:44 AM.Willing to help but I'm no expert.Comment
Re: 715g6338+psu.
With the mainboard still disconnected and the resistor still in place what voltage do you have when you put your meter leads across ZD9330 and power up out of standby?Willing to help but I'm no expert.Comment
Re: 715g6338+psu.
I need to clarify. When you mean mainboard you mean the second pic which connects to the screen and stuff ya.
And when you mean bring it out of standby I connect the ancillary items from the cable in the first pic ya? And I turn on the remote yes?
When tested with no connection, I get .05v
When tested with the ancillary connection similar. Sometimes it goes to .07.
When I turn on the remote it goes to 15v.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: 715g6338+psu.
Post a picture of the back of your set showing all the circuit boards.
To confirm. You have 15V across ZD9330 when you use the remote to come out of standby, yes?
If so it looks like the PS_ON is switching on transistor Q9333 to supply VCC_ON (15V) to IC9801 and IC9101
What is the voltage now across C9812. It was about 300V but should be approx 380V
With the set off check the resistance of R9107 and R9815 and please give resultsLast edited by dick_barton; 04-07-2020, 04:57 AM.Willing to help but I'm no expert.Comment
Re: 715g6338+psu.
So the boost circuit IC9801 is working.
Do you now have the +36V/+24V ?
Boards pic layoutAttached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by dick_barton; 04-07-2020, 05:54 AM.Willing to help but I'm no expert.Comment
Re: 715g6338+psu.
You do not want the mainboard connected to the power supply when carrying out checks on the power supply to avoid damaging the mainboard.
It looks like you have a faulty IC9101 or a component around that IC is faulty. Perhaps as you initially thought the transformer T9101, although it would be unusual.
With the set still powered off what is the resistance from the +36V/+24V line to ground. Can you also check the resistance of D9104 with your meter set to diode mode.
With the set powered off you can measure the resistance of the transformer.
Pin 1 - 2 =
Pin 3 - 4 =
Pin 3 - 5 =
Pin 4 - 5 =
They should all be very low resistance.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by dick_barton; 04-07-2020, 07:01 AM.Willing to help but I'm no expert.Comment
by corrizeHello,
I have different sort of those little BGA chips (step down DC-DC, power management battery, …) I replaced 10 on differents mobile devices (no schematics) but I noticed often they can be dead but never shorted. I see some signs : burn marks, resistance drop by comparison with good board (40 KOhms to 1 KOhms for example)… but not easy to be sure of the diagnose. Because I can't access on all tracks (balls) with the meter.
Sometime, I know only after replacing chips.
Do you have tips for diagnose please ?
Phillips OLED TV 55P0S9002/05 715G8886-P01-000-004Y Schematic
Brand: Philips
MPN: 55POS900255
GTIN: 8718863012352...-
Channel: Schematics and Boardviews
How do I find my "board path" as shown on openboarddata.org ?
Full model: Mid-2012 Macbook Pro 15" Retina A1398 (EMC 2512) MC975LL/A02-14-2024, 12:30 AM -
by groomitHello,
currently I'm tinkering with above mentioned broken device. It started with a shorted PD controller. I replaced it and have an open topic on this forum on reprogramming it.
Currently I'm powering it with a bench supply soldered to the battery connector (laptop battery is dead).
This way the device is booting into BIOS and Diagnose mode fine. But when I try to restore the factory image during diagnose the laptop always greets me with "no bootable device".
Looking at the bios the ssd is recognized (shown with type and size in some storage menu). But... -
by learnmoreHello Community,
Would welcome any help on getting a service manaula for the above model (Phillips 75PUS6754/12) TV or anything similar.
Picture intermittently works fine for a day or a minuite then goes off, but backlights appear to remain on.
I thinking troubleshooting TV or using a tape method on the panel but would like some guidance on tracing the signals accurately rather than a trail and error.
Thanks in advance,
LM - Loading...
