Lg 50lb659y stuck in startup with lg logo.
  • Swisalem
    • Mar 2020
    • 5
    • Israel
    I see alot of videos in youtube and all dont work, i try to update firmware but i dont found in lg site this model.
    Someone know what to do?
    Thanks!
  • CapLeaker
    Leaking Member
    • 8206
    Re: Lg 50lb659y stuck in startup with lg logo.
    reflow the main IC on the main board or bake the main board. These are known to have BGA issues as well.
    • Swisalem
      • Mar 2020
      • 5
      • Israel
      I try to bake the main board but nothing, i bake for 10 min on 150 celcius.
      I dont understand the first option.
      Thank for the help!
      • diif
        • Feb 2014
        • 6978
        • England
        It's not a cake !! It needs 217c to melt lead free solder.
        • Swisalem
          • Mar 2020
          • 5
          • Israel
          Try again?
          • diif
            • Feb 2014
            • 6978
            • England
            Originally posted by Swisalem
            Try again?
            Yes, you are wanting to re melt the solder balls under the main processor, however using an oven will all of the solder so be careful, don't bump it, open the oven door to let it cool before touching it.
            Ideally with some flux if you have some although fumes in your food oven aren't the best.
            • Swisalem
              • Mar 2020
              • 5
              • Israel
              After i try this, still the screen stuck on lg logo...
              Another options?
              If you want photos i can post.
              Thanks!
              • edugimeno
                Te systems tv stuck in startup logo
                by edugimeno
                Hi there!
                This tv set (TD systems) is posted for sale with this issue.
                Stuck in boot up logo
                Is this something that can be fixed easily like an USB fw upgrade?
                Or does it need any specific hardware programming adapter?
                Thanks in advance!!...
                06-27-2023, 09:02 AM
              • x_orange90_x
                Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                by x_orange90_x
                I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                12-28-2023, 06:26 AM
              • Udara Umayanga
                Toshiba C850 Getting stuck on startup logo
                by Udara Umayanga
                Hello friends,
                I have Toshiba C850 Laptop when it is power on it was stuck on Toshiba logo.
                I was try to solve it but cant please help.
                I was reset CMOS , remove hard drive , remove battery and change ram and I did many more things.. But nothing doing any thing Please help..
                Thanks,
                Udara
                08-05-2022, 11:43 AM
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
              • justice171
                JVC LT-50N795 Stuck on Wisdom Share Logo
                by justice171
                I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                Thanks in advance!
                11-04-2024, 02:55 AM
