Sony 46HX900 power supply dead
  • renee
    • Jun 2010
    • 21
    Re: Sony 46HX900 power supply dead
    So you are saying that you took those caps off and checked them with an esr meter??
    All checked all ok
    • renee
      • Jun 2010
      • 21
      thanks to all
      problem solved
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Are you going to say how it was resolved?
          • 12332
          • U.S.
          Uh...yeah what Dick said...how was resolved??
          • renee
            • Jun 2010
            • 21
            due to bad cap C6252 470uf 16v was leaked
            • renee
              • Jun 2010
              • 21
              #26
              i have another issue with this Sony 46HX900 now giving 6 blinks fault
              As i ON the led it runs smoothly on day light scene and go to standby mode as night scene show in movie or dark image show
              i dont know what kind of fault is this
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • Andreas_de
                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                by Andreas_de
                Hello!
                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                04-12-2025, 10:38 AM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
