Hi Everyone,
I've been poking though the forum and have got a lot of great info so far but I'm at a loss at this point and was turning to the forum for some assistance.
I have been troubleshooting my UN65JS9500 TV where there is no backlight. Upon further investigation of the Power Supply / LED Board BN44-00818A when testing the CN803 connector(circled in green) which goes to the LED control board I have Pin 1 - 5v and Pin 3 -13V but I would expect to see 32V on PIN 14 - PIN 21, there is no voltage.
I have continued to investigate and found no voltage at TM901CS (circled in pink) which I believe is responsible for generating the 32V for the Vdrv outputs but I also haven't located the schematic for this board either.
If I look at the board correctly there is a THICK black line which I believe depicts AC vs DC. ie DC in the upper left if looking at the top of the board and everything else is AC.
I found FP903S (Circled in red) to be faulty and replaced it however when the board was powered on the fuse blew. The fuse I replaced it with was Schurter Inc. / 0001.2509.PT which is a 3.15A Slow Blow 250V fuse.
If I trace back from FP903S I come to the middle leg of DP807C(circled in blue). Does anyone know what the voltage output and current should be? Or have a datasheet for SFI608PT or is it SF1608PT?
I've attached high res photos from shopjimmy to help with the identification. Any guidance would be appreciated.
