Optocouplers
  • Eel_dahc
    • Apr 2017
    • 18
    Optocouplers
    I got a free Polaroid flm 323 TV and I am assuming that the power supply is bad because I don't get any voltages like shown on Copp#ll tv site or youtubes. But I have it at the main cap. I already replaced a couple of diodes and tested the caps.
    This is just for me to learn on and try to fix.
    So I was wondering about the optocouplers. Took them off to test. Using a DMM I got nothing in diode mode up to 200k. My little lcr-t4 didn't find anything.
    Using a tester i rigged up with a 3.7v battery, led and 1k res on breadboard and only one lit up and it lit up once. The other 3 did not. So I wonder if I either blew them up or they didn't work anyway.
    I have plenty of scrap power supplies from old crts, satellite boxes and PC. Would those optocouplers be safe to use or are they all different like transistors and mosfets?
  • petehall347
    • Jan 2015
    • 4437
    Re: Optocouplers
    check the datasheets .
    • zwect
      RTX 4060 Gigabyte Aero / FBVDDQ not switching on despite compatible IC swapping
      by zwect
      I got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...
      07-21-2025, 05:53 PM
    • Peter_1402
      Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
      by Peter_1402
      Hi Everyone,
      I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
      1. Soldering iron works great
      2. There is a burnt mark on the hot air gun handle.
      I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
      Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
      Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
      Reed switch tested ok with a magnet.
      From the above test, I can conclude...
      07-12-2025, 11:50 AM
    • master3112
      Acer Spin 3 SP314-54N, Mainboard Lenny_ICL 19771-1 no power,
      by master3112
      Hello everyone.
      I have an Acer Spin 3 SP314-54N, mainboard: Lenny_ICL 19771-1.
      The device does not start. I have 19V at the input of the PU4408 (AON21321). Gate voltage is also 19V but the MOSFET is not opened. I have also replaced the MOSFET and it is OK. The gate voltage is provided by two resistors PR4418 (200k) and PR4419 (100k). I unsoldered both and measured them, all okay.I also desoldered and measured the PC4453, which is OK. I desoldered the PU4408 and short-circuited pads 1-3 with pads 5-8. Then the device started normally. Does anyone know what gate voltage the PU4408 should...
      02-11-2025, 10:02 AM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • ngml
      Repair of an LG split AC system indoor unit PCB
      by ngml
      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
      This indicates an error in the communication between the outdoor and the indoor unit.
      The outdoor unit is fine, so the problem is the indoor PCB.
      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
      Does anybody have the schematics of this board,...
      02-01-2025, 12:55 PM
